Abnormal storage visualisation and extra high traffic
is this same issue? available space on T drive should be 900GB more than total node size…checked filwealker with and says finished only for decom satellites,…why?
2024-06-07T09:22:08+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {“satelliteID”:
“12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”}
2024-06-07T10:09:58+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {“satelliteID”:
“12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”}
2024-06-11T22:41:59+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {“satelliteID”:
2024-06-12T01:23:53+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {“satelliteID”:
found this:
2024-06-14T00:40:53+02:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {satelliteID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6}
2024-06-14T00:40:53+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {satelliteID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, error: context canceled}
2024-06-14T00:40:53+02:00 ERROR pieces failed to lazywalk space used by satellite {error: lazyfilewalker: context canceled, errorVerbose: lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78, Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6}
Hello @majklsee ,
Welcome back!
Seems you didn’t remove their data
This is mean that your disk is too slow to keep-up and the lazy filewalker is failed.
You need to optimize this disk - check and fix errors, perform a defragmentation.
You may also tune it to be faster:
