After reboot, the node does not start. Version 1.146.8 PLEASE HELP!
I agree most problems with hashtbl started from 1.145 version
it started magickly disappear from nodes or go broke.
Before that was not problems.
Same for me. I downgraded to 1.144.3 and everything is back to normal. I had to run write-hashtbl multiple times after I upgraded.
I believe you could stop the updater service and replace the storagenode binary with the old one. I didn’t tried it, but this seems logical.
I believe that this version has issues:
So, it’s better to downgrade. The stable one is on https://version.storj.io
However, you may also try to use a latest release: Release v1.147.5 · storj/storj · GitHub
almost correct, but you need to stop both services, storagenode and storagenode-updater before replacement, Windows doesn’t allow to replace a running binary.
