I know. I mean - take its suggestion as a serious offer.
I don’t have physical access to this node and drive.
And will not have for at least a week.
By the way, in your installation instruction, i found some new things, that i haven’t seen when i was installing node. It’s about
sudo chown -R pi:pi /mnt/storj
So i run this command, it takes ages, but after like 10min. o silent it gave me ~8 folders inside /Blobs that "chown: changing ownership of …/storage/blob/asdasc… : Structure needs cleaning
and node is online for more then 20min now. But the chown process still not finished.
That’s another signal that you’re running into issues with your disk. It could simply be a file system issue. Please run fsck on it.
Thank you !!! This helped !
Node running fine again! used space - correct. Everything nice
