did it help to resolve an offline issue?
No, i think its not even completely booting up, now.
Perhaps you cleared too much. I think you may try to reinstall docker, it should restore missing rules.
Yep tried reinstalling docker, once with a simple apt reinstall
Then a full apt remove, then apt install.
It didnāt help
Then just for shits and giggles i apt reinstall iptables, and i think that cleaned it up a bit
[storjnode]:</home/mike/> sudo iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy DROP)
DOCKER-USER all -- anywhere anywhere
DOCKER-ISOLATION-STAGE-1 all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
DOCKER all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (1 references)
ACCEPT tcp -- anywhere 172.17.0.3 tcp dpt:28967
ACCEPT udp -- anywhere 172.17.0.3 udp dpt:28967
ACCEPT tcp -- anywhere 172.17.0.3 tcp dpt:14002
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2 all -- anywhere anywhere
RETURN all -- anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
DROP all -- anywhere anywhere
Chain DOCKER-USER (1 references)
Buttttt it hasnāt helped, tail 20 of the log:
2023-03-20T08:20:35.035Z ERROR preflight:localtime unable to get satellite system time {"Process": "storagenode", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "error": "rpc: tcp connector failed: rpc: dial tcp: lookup us2.storj.io on 8.8.4.4:53: read udp 172.17.0.3:44312->8.8.4.4:53: i/o timeout", "errorVerbose": "rpc: tcp connector failed: rpc: dial tcp: lookup us2.storj.io on 8.8.4.4:53: read udp 172.17.0.3:44312->8.8.4.4:53: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189"}
2023-03-20T08:20:35.035Z ERROR preflight:localtime unable to get satellite system time {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io on 8.8.4.4:53: read udp 172.17.0.3:35758->8.8.4.4:53: i/o timeout", "errorVerbose": "rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io on 8.8.4.4:53: read udp 172.17.0.3:35758->8.8.4.4:53: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189"}
2023-03-20T08:20:35.035Z ERROR preflight:localtime unable to get satellite system time {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io on 8.8.4.4:53: read udp 172.17.0.3:59892->8.8.4.4:53: i/o timeout", "errorVerbose": "rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io on 8.8.4.4:53: read udp 172.17.0.3:59892->8.8.4.4:53: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189"}
2023-03-20T08:20:35.036Z ERROR preflight:localtime unable to get satellite system time {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io on 8.8.4.4:53: read udp 172.17.0.3:43120->8.8.4.4:53: i/o timeout", "errorVerbose": "rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io on 8.8.4.4:53: read udp 172.17.0.3:43120->8.8.4.4:53: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189"}
2023-03-20T08:20:35.036Z ERROR preflight:localtime unable to get satellite system time {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io on 8.8.4.4:53: read udp 172.17.0.3:47471->8.8.4.4:53: i/o timeout", "errorVerbose": "rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io on 8.8.4.4:53: read udp 172.17.0.3:47471->8.8.4.4:53: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189"}
2023-03-20T08:20:35.036Z ERROR Failed preflight check. {"Process": "storagenode", "error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:885\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:377\n\tstorj.io/private/process.cleanup.func1:395\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:92\n\tmain.main:478\n\truntime.main:250"}
Error: system clock is out of sync: system clock is out of sync with all trusted satellites
2023-03-20 08:20:35,060 INFO exited: storagenode (exit status 1; not expected)
2023-03-20 08:20:36,064 INFO spawned: 'storagenode' with pid 26
2023-03-20 08:20:36,065 WARN received SIGQUIT indicating exit request
2023-03-20 08:20:36,066 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2023-03-20T08:20:36.066Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2023-03-20 08:20:36,067 INFO stopped: storagenode-updater (exit status 0)
2023-03-20T08:20:36.124Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2023-03-20T08:20:36.125Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2023-03-20T08:20:36.127Z INFO Operator email {"Process": "storagenode", "Address": "mo...om"}
2023-03-20T08:20:36.127Z INFO Operator wallet {"Process": "storagenode", "Address": "0x38...4b5"}
2023-03-20T08:20:36.139Z INFO server kernel support for server-side tcp fast open remains disabled. {"Process": "storagenode"}
2023-03-20T08:20:36.139Z INFO server enable with: sysctl -w net.ipv4.tcp_fastopen=3 {"Process": "storagenode"}
2023-03-20 08:20:39,144 INFO waiting for storagenode, processes-exit-eventlistener to die
and cmdline dashboard:
2023-03-20T08:22:17.936Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2023-03-20T08:22:17.939Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2023-03-20T08:22:17.943Z INFO Identity loaded. {"Process": "storagenode", "Node ID": "12c8JB6mnmQhDgh2fbHC9f5bp8ByqM1pDsyzFkzVsQQaEvg6T7u"}
Error: manager closed: read tcp 127.0.0.1:54184->127.0.0.1:7778: read: connection reset by peer
the network still doesnāt work.
Is it possible that your VM has not unique IP in your network or it did not match allowed subnet for your modem (router)? And could you try to change the DNS server for it to 8.8.8.8 for example instead of 8.8.4.4?
Yep , iām sure i havenāt duplicated the IP address, as i said its static, and i donāt have that many static addresses.
the DNS entries i originally had was what is given out by my cablemodem.
I have changed them a couple of times, and now just 8.8.8.8
It just puzles me, how it can figure out the address to download the updater, but apparently nothing else
downloading storagenode-updater
--2023-03-21 07:15:18-- https://version.storj.io/processes/storagenode-updater/minimum/url?os=linux&arch=amd64
Resolving version.storj.io (version.storj.io)... 34.173.164.90
Connecting to version.storj.io (version.storj.io)|34.173.164.90|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 92 [text/plain]
Saving to: 'STDOUT'
0K 100% 124M=0s
2023-03-21 07:15:19 (124 MB/s) - written to stdout [92/92]
--2023-03-21 07:15:19-- https://github.com/storj/storj/releases/download/v1.74.1/storagenode-updater_linux_amd64.zip
Resolving github.com (github.com)... 140.82.113.3
Connecting to github.com (github.com)|140.82.113.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/128089774/a0d3da67-436e-4d47-b00a-d9831ec51589?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20230321%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20230321T071520Z&X-Amz-Expires=300&X-Amz-Signature=a15db5ce6cb52408395b87140ab8d08fbab30ef52f18009f2dd6fdcda84fb6f0&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=128089774&response-content-disposition=attachment%3B%20filename%3Dstoragenode-updater_linux_amd64.zip&response-content-type=application%2Foctet-stream [following]
--2023-03-21 07:15:19-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/128089774/a0d3da67-436e-4d47-b00a-d9831ec51589?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20230321%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20230321T071520Z&X-Amz-Expires=300&X-Amz-Signature=a15db5ce6cb52408395b87140ab8d08fbab30ef52f18009f2dd6fdcda84fb6f0&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=128089774&response-content-disposition=attachment%3B%20filename%3Dstoragenode-updater_linux_amd64.zip&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.108.133, 185.199.111.133, 185.199.110.133, ...
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.108.133|:443... connected.
Length: 9141974 (8.7M) [application/octet-stream]
Saving to: '/tmp/storagenode-updater.zip'
Wouldnāt you think DNS resolution would wwork all the time, or none of the time ?
How about we just wipe it out and rebuild it, this doesnāt seem to be getting me anywhere ?
plus we could have had it rebuilt within a couple of hours.
one time i had a duplicated mac address, because i had cloned a vm.
I never clone, and just usually deploy templates, and i would think vmware handles that correctly, otherwise spinning up vms would be a nightmare.
i use mac addr for dhcp allocation.
its possible the mistake was mine because the vm needed the same ip for port forwarding.
was a bit of a pain to troubleshoot
I probably might prefer that, but my cablemodem doesnāt have that feature.
One way i try to get around that is using avahi-daemon, then you just use the name ind it discovers.
i stopped using my commercial router and now run pfsense⦠its been great.
tho today i might have used opnsense instead, but they are very much the sameā¦
pfsence is very good thing, but for people who know what they do. normal user cant handle it.
lol, i used to be a network professional, now i just want the easiest way to use it.
Perhaps this would be easier, just make sure that your identity and data in safe (please do not wipe them with VM
), and do not forget about databases if you moved them.
identity is on the system drive āsda2ā, the ā/dataā is on sdb1, the larger drive for Storj.
Itās always better to keep your identity together with data, they are useless without each other anyway.
So did i miss a step somewhere? Why doesnāt āidentity createā just place them there ?
Because you create the identity before you setup the node.
