eikaf
March 25, 2022, 3:40pm
1
Hi all,
I am experiencing some failed audits on my node
1tp9Btrz7Ehxq4M5ChREygSXMXGsUz4yrXS9icRbkovBJf1fd3
Version 1.50
I tried to “grep -E “GET_AUDIT|GET_REPAIR” /media/storagenode/node.log | grep failed” but last failed error is on 2021-11-26. Really do not know what is happening here.
Any hints?
Earnings.py script shows US1 only Status: WARNING: Audits failing (SUSP 7.11%)
Thanks all.
If you would share the error message we might be able to tell you what is going on.
eikaf
March 25, 2022, 5:43pm
3
I think that error is not related to my audit issue, since it is from 4 months ago.
No errors appearing in the log in these last days.
What can i check?
edit: “cat /media/storagenode/node.log | grep 2022 | grep error” showing no error.
Alexey
March 25, 2022, 6:00pm
4
You need to search for ERROR, the grep is case sensitive. And filter only GET_AUDIT and GET_REPAIR, all other will not affect the audits score.
eikaf
March 25, 2022, 6:31pm
5
Thanks for reply.
eikaf@storjnode:~$ cat /media/storagenode/node.log | grep 2022 | grep FAILED
eikaf@storjnode:~$ cat /media/storagenode/node.log | grep 2022 | grep ERROR
eikaf@storjnode:~$ cat /media/storagenode/node.log | grep 2022 | grep failed
eikaf@storjnode:~$
Maybe it’s a misreading from earning.py script.
Alexey
March 25, 2022, 7:03pm
6
No, it’s mention that your have drop in suspension score. There should be some errors. Are you sure that you check the right file?
