Bring SN to another city
Hi team,
is that possible or will i get dq because of the ip change?
What do i have to do?
Thanks!
Changing node IP is fine.
You’ll need to open the port forwarding at the new location and then update config.yaml with your new IP or DynDNS name.
Edit - you should make sure the downtime is as minimal as possible (must be less than 288 hours in 30 day period - although this will currently only cause suspension not dq)
And also make sure that you shutdown the DDNS updater in the old place. If you configured it in the router - it’s easy to forget.
