Canadian Node Operators
Now I am even more surprised you made this post, I had assumed you lived in a more rural region.
The residential electricity in Vancouver is ~0.14 CAD/kWh on Tier 2, and at this price, with a somewhat idling server at say 50W, this is ~50 CAD/year. To earn this much in the year you’d just need to store on average 2TB/mo.
What probably holds this back is the held-back mechanism, so you aren’t seeing the whole profits immediately, and if you are only just earning on 2TB/mo you’re likely not getting payments on L1 so cashing out can be hard at this small scale.
I’ve run across that number a few times now. In that different SNOs have said the first 2TB stored in any node just goes to cover its monthly operational costs (power/cooling/internet/slot/etc): and that you don’t make any money until it gets larger (and obviously leaves the 9-month withholding period).
Good rule-of-thumb!
Hello my fellow Canadian and resident of beautiful British Columbia.
Jut a reminder for everyone to keep it civil in the thread.
Looks like residential electric costs vary a lot by region.
This is from 2023. I’m sure our Canadian members know more about current rates.
You can’t take a walk to the store in Quebec without tripping over a hydroelectric dam. Power is so cheap!
It was hosted on a multi-use server sucking up 500W at idle because it’s a G34 quad socket motherboard that was mass produced circa 2016 when power was only 0.06/kwh. I don’t blame Storj for the expensive hardware choices I made.
I am running SAS3 20TB exos drives on a quad socket motherboard purely for the extra memory capacity for the workloads that requires it.
Turning off fully operational nuclear power plants is working as intended, it seems. Along with excessive wind farms, producing zero power when there’s no wind. Electricity in cold, windless night must come from somewhere (hence the record cost).
