Hello
I was running a V2 node for a long time and switched to V3, so I’m somewhat familiar with setting up the node.
For some reason my “status” shows offline.
I did port forward and setup my IP with DNS, but it still shows offline. And I even disabled my windows firewall to see if it would help.
My uptime is at 16hours and last contact is 17699945h 27m ago.
I’m running V 0.34.6
Uptime checks is 0% and audit checks is 100%
I’m not sure what else to do!
Welcome to the forum @KingBennon !
Can you verify if your identity folder has 6 files in it ?
Alexey
March 14, 2020, 5:46pm
3
Please, check that the contact.external-address:
is specified with a port, like this
contact.external-address: your.ddns.address:28967
You can see your current parameter:
sls "external-address" 'C:\Program Files\Storj\Storage Node\config.yaml'
Hello
My folder has 4 files
ca.cert
ca.key
identity.cert
identity.key
also just checked the log, think i may have forgotten to do something.
2020-03-13T17:13:20.469-0700
INFO
Configuration loaded from: C:\Program Files\Storj\Storage Node\config.yaml
2020-03-13T17:13:20.472-0700
INFO
Invalid configuration file key: storage.allocated-bandwidth
INFO
Invalid configuration file key: contact.external-address
INFO
Invalid configuration file key: server.address
INFO
Invalid configuration file key: operator.email
INFO
Invalid configuration file key: storage.allocated-disk-space
INFO
Invalid configuration file key: storage.path
2020-03-13T17:13:20.478-0700
INFO
Invalid configuration file key: server.private-address
2020-03-13T17:13:20.479-0700
INFO
Invalid configuration file key: server.debug-log-traffic
INFO
Invalid configuration file key: operator.wallet
2020-03-13T17:13:20.713-0700
INFO
Downloading versions from
2020-03-13T17:13:21.085-0700
INFO
storagenode version is up to date
INFO
2020-03-13T17:13:21.180-0700
INFO
storagenode-updater version is up to date
2020-03-13T17:28:20.656-0700
INFO
2020-03-13T17:28:20.915-0700
INFO
INFO
2020-03-13T17:28:20.956-0700
INFO
I deleted the " Downloading versions from" stroj links as it wont let me post with more than 2
Also for the “contact.external-address: your.ddns.address:28967”
I had my IP address:port
I changed it to my ddns address:port
KingBennon:
Your identity is not signed. It needs to have 6 files in it.
Refer the documentation: Step 5. Create an Identity - Storj Docs
I thought I did.
I’m going to make a new key make sure its right.
I will let you know what happens.
Thank you!!
OK, Im a dumb ass!!
Your right my identity was not signed!
Everything is working now.
Thank you so much!!
