Changelog v1.22.2
Thank you. Your full link is clear :slight_smile:
Is the rmem_max value the same as filestore.write-buffer-size for the Docker containers (my launch script already sets this to a larger value for my SMR drives)? Also, should the documentation be updated to notify when installing that this needs to be changed or can the application automatically check and change this to a recommended value?
No, it’s a different values - the first one is kernel-related,
the second one is a software related.
It will be documented when the feature is ready and tested.
I hope tcp only connection will be also supported.
There are cases when tcp port forwarding is working fine but tcp + udp looks really tough to setup. At least in my case.
Tough in what way? From the network setup perspective, the change from TCP to TCP+UDP rules is as simple as switching a value from TCP to TCP+UDP in most cases, at worst you need another rule. At least in any router I’ve ever seen.
It is a bit more complex when you don’t have static ip.
I might start searching for good vpn options if tcp only connection that I have won’t work. If actually vpn will be a working option.
Best :grinning::grinning::grinning:
:pinching_hand: :skunk:
:rofl:
Awesome! :+1:
I think most don’t have static IP here. I’m without a static IP and the TCP vs TCP+UDP setup is identical…
Amazing. Where do I press for bonus points here?
