This is interesting.
You can change this parameter:
To the 400.0 GB, save the config and restart the node. It should be up and running.
Your database seems to missed some stored pieces on your disk. Luckily the audit checking doesn’t use this database to locate the pieces.
But I think you will see a discrepancy on your dashboard.
I wiped my drives to start over. Shame to wipe all the data, but it was not looking like it was fixable. Should I use the same identity to start the new node?
I used same identity, it has already downloaded almost 1GB. Everything looks to be working fine.
I think I know what happened. I had my size set to 1.35TB on a 1.4 TB file system. I don’t think I left enough overhead and that could have corrupted the DB (per the install guide). Although I don’t recall the drive ever getting close to 100%, it could have I don’t keep that close an eye on it. I now have it set to 1.25TB which is over the 10% recommended.
Looks like you kind of brought this one on yourself, but you’re going to have to start over once more. To the network the same identity means the same node. Which means it will look for your old data on your current node, which won’t be there. It will be disqualified very soon for this reason. There is no need to wait this out, it will happen. Save yourself the time and start completely clean now, with a new identity and token.
