Out of curiosity, are there any documents describing the changes to the protocol being made?
It could help only for pieces with an expiration date. But for that we have a cache in the DB, so these pieces are deleted directly by the collector (it’s not a full scan like used-space-filewalker or partially full scan by gc-filewalker after BF is received), so these folders will not help much for GC by BF, because it’s by pieceids, not by date (and the current folders structure actually helps to locate them faster, unfortunately not for BTRFS). Yes there is a last running date for GC, because otherwise BF may delete a wrong pieces (because of different seed), but it’s not related to date when the piece has been created.
when its save to delete data from trash folder manually and should i do that?
This screenshot is from today. So what is better? Leave it for garbage collector or delete that folders manually (They are definitely older than 10 days. Node was rest restarted manually several times. Current version is 101+ And it’s happened on several nodes.)
Is that folder empty ?
No, they are not empty. approximately. 25 gigabytes and as usual, tons of folders.
Then leave it as is. It will be deleted automatically. It’s deleted by a separate chore for the trash, it’s running every day and removes all data older than 7 days. Seems the folder may remain.
Please show a result of the script:
Does the storagenode log contain anything about trash-cleanup-filewalker or trash-filewalker. You can search this with grep -E "trash-cleanup-filewalker|trash-filewalker", if you have grep installed.
There could be few reasons that it’s not working, e.g.
- there’s some file that’s preventing the folder being deleted
- there’s some program that’s preventing it from deleted
- there’s some disk issue
- there’s some issue starting the program that cleans the trash folder
- there’s some bug/issue related to deleting the trash
- probably something that I cannot think of at the moment
And yes, trash that’s older than 10 days is safe to delete. However, this may happen again.
On my disk I also have an empty folder. I have the feeling it could be the migration from the old folder structure to the new folder structure. The moment I installed the new storage node version the trash folder content was migrated to the new folder structure. In my case the trash folder was empty. In his case it was not empty. This folder was generated by the migration and not by garbage collection. I don’t know why that would make a difference but maybe you have an idea.
During the migration, trash that exists from before are all migrated to the new per-day directory structure under the current-day directory the first time a node runs. So all the trash pieces are moved to a single directory with the current date as the folder name (This means some of the pieces might stay longer than they should but that’s okay). I expect at most one empty directory due to the migration if no trash data was available during the migration, because the folder is first created for each satellite namespace in the trash directory and then tries to move all at once without traversing the namespace. That empty folder will still be deleted after 7 days.
GC (retain) also moves trash pieces but this time follows the new per-day directory format. If there’s more than one per-day folder in the trash, then the rest were definitely from GC
Well it isn’t. I am sitting in the same boat. I have a folder that is almost a month old and still not deleted.
Can you check the logs for anything about trash-cleanup-filewalker or trash-filewalker ?
We have always had empty folders in trash sometimes numbering in thousands.
Node is currently at 1.99.3
root@datengrab:/mnt/sn2/storagenode2/storagenode/storage/trash/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa# ls
2024-03-14
root@datengrab:/mnt/sn2/storagenode2/storagenode/storage/trash/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa# ls *
root@datengrab:~# grep 'trash-cleanup-filewalker' /home/storagenode/logs/storagenode2.log
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-04-07T18:26:13+02:00"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "dateBefore": "2024-04-07T18:26:13+02:00"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-04-07T18:26:13+02:00"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-14T18:26:13+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-04-07T18:28:15+02:00"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "dateBefore": "2024-04-07T18:28:15+02:00", "Process": "storagenode"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-04-07T18:28:15+02:00"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-14T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-15T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-15T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-15T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-04-08T18:28:15+02:00"}
2024-04-15T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-04-15T19:29:34+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 279872397312, "numKeysDeleted": 452961}
2024-04-15T19:29:34+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "dateBefore": "2024-04-08T19:29:41+02:00"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-04-08T19:29:41+02:00"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-15T19:29:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "dateBefore": "2024-04-09T18:28:15+02:00", "Process": "storagenode"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "bytesDeleted": 0, "numKeysDeleted": 0, "Process": "storagenode"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "dateBefore": "2024-04-09T18:28:15+02:00", "Process": "storagenode"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-04-09T18:28:15+02:00"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "numKeysDeleted": 0, "Process": "storagenode", "bytesDeleted": 0}
2024-04-16T18:28:15+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-04-09T19:34:53+02:00"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T19:34:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "dateBefore": "2024-04-09T19:34:53+02:00"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "bytesDeleted": 0, "numKeysDeleted": 0, "Process": "storagenode"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-04-09T19:34:54+02:00"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-16T19:34:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-04-09T21:20:14+02:00"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "dateBefore": "2024-04-09T21:20:14+02:00"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-04-09T21:20:14+02:00"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-04-16T21:20:14+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
To be continued
root@datengrab:~# grep 'trash-filewalker' /home/storagenode/logs/storagenode2.log
The new per-day structure in v1.101+ solves this as well
I see a successful trash cleanup for eu1 on the 15th? Do you have trash folders for eu1 older than that? Or are they empty?
What version is the node running on? If lower than v1.101, you should wait for it to be updated to v1.101; we are still rolling out v1.101.3.
v1.99.3
20 charaptes
