It’s been said several times now. It won’t end, hopefully at least. These tests are representative for prospective customers usage patterns and if those contracts get signed, all we will see is a shift from Saltlake to customer satellites, with the same usage pattern. You’re still getting paid for all this data. I don’t see the issue.
Did any staff comment on the lifetime of the pieces of these tests? I think many would like to avoid situations like these past weeks with significant drops in used space from the saltlake satellite, where those pieces have been there for years.
Piece expiration is set to 30 days. That’s all we know.
Hard to believe. 30 day ingress for SLC was 15 PB but only 3 PB used space. ![]()
Nothing says pieces can’t be removed earlier with the regular GC means. All I can say is that when looking into the pieceexpiration.db file, I see 30 days.
Perhaps on your node?
Did it finish all filewalkers including the Garbage Collector for each trusted satellite?
See
No, everything seems to be fine with me, all 4 satellites have been successful on all 3 nodes. Can you see the filters yourself or when they arrived or are they not saved locally?
We cannot see that, it’s only local.
Please check, that all 5 filewalkers are finished for all 4 trusted satellites.
Sorry, of course I meant whether I can see the bloom filter on my computer? If yes then where?
Why 5 filewalkers? for all 3 nodes all 4 filewalkers were successful.
Node 1:
Summary
2024-06-05T17:42:55+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-05T17:42:55+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-06-05T17:42:55+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "createdBefore": "2024-05-30T17:59:59Z", "bloomFilterSize": 4667513}
2024-06-05T17:54:41+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-05T21:00:53+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-05T21:00:53+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-06-05T21:00:53+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "createdBefore": "2024-06-01T17:59:59Z", "bloomFilterSize": 867872}
2024-06-05T21:17:16+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-05T21:44:26+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-06T07:42:37+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-06T07:42:38+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-06-06T07:42:38+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "createdBefore": "2024-06-01T17:59:59Z", "bloomFilterSize": 4729727}
2024-06-06T13:53:03+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-06T13:53:03+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-06-06T13:53:03+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "bloomFilterSize": 215507, "Process": "storagenode", "createdBefore": "2024-06-02T17:59:59Z"}
2024-06-06T13:57:24+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-07T07:28:52+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Node 2:
Summary
2024-06-05T21:36:13+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-05T21:36:14+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-06-05T21:36:14+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "createdBefore": "2024-05-30T17:59:59Z", "bloomFilterSize": 8668127, "Process": "storagenode"}
2024-06-05T23:14:46+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-05T23:14:46+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-06-05T23:14:46+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "createdBefore": "2024-06-01T17:59:59Z", "bloomFilterSize": 1198838}
2024-06-05T23:49:33+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-06T02:44:06+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-06T03:02:16+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-06T08:18:01+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-06T08:18:01+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-06-06T08:18:01+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "createdBefore": "2024-06-02T17:59:59Z", "bloomFilterSize": 264157}
2024-06-06T08:30:05+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-06T10:09:35+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-06T10:09:35+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-06-06T10:09:35+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "createdBefore": "2024-06-01T17:59:59Z", "bloomFilterSize": 4689231}
2024-06-07T08:10:12+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Node 3:
Summary
2024-06-05T06:10:30+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-05T06:10:30+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-06-05T06:10:30+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "createdBefore": "2024-05-30T17:59:59Z", "bloomFilterSize": 3905357}
2024-06-05T23:09:46+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-05T23:09:47+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-06-05T23:09:47+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "bloomFilterSize": 8196159, "Process": "storagenode", "createdBefore": "2024-05-30T17:59:59Z"}
2024-06-06T06:17:05+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-06T06:17:05+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-06-06T06:17:05+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "createdBefore": "2024-06-01T17:59:59Z", "bloomFilterSize": 1012040}
2024-06-06T06:56:02+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-06T09:27:35+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-06T13:13:09+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-06T13:13:09+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-06-06T13:13:09+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "createdBefore": "2024-06-02T17:59:59Z", "bloomFilterSize": 245109}
2024-06-06T13:24:39+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-07T03:20:51+02:00 INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
You showed only 1 filewalker. gc-filewalker. It’s important, but you have 4 more.
As far as I can tell, everything is ok and works as it should. But what does that have to do with whether I get new bloom filters?
Node 1:
Used space filewalker
2024-05-24T15:55:00+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-05-24T15:55:00+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-05-24T15:55:00+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-05-24T15:59:05+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-05-24T15:59:05+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-24T15:59:05+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-24T15:59:05+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-24T16:07:31+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-24T16:07:31+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-24T16:07:31+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-05-24T16:07:31+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-05-24T16:36:01+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-24T16:36:01+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-24T16:36:01+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-05-24T16:36:01+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-05-24T16:39:19+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
GC filewalker
Trash-cleanup filewalker
2024-06-08T15:55:00+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-08T15:55:00+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-06-01T15:55:00+02:00"}
2024-06-08T15:55:00+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-06-08T16:08:55+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-08T16:08:55+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-08T16:08:56+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "dateBefore": "2024-06-01T16:08:55+02:00"}
2024-06-08T16:08:56+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-06-08T16:12:20+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-08T16:12:20+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-08T16:12:20+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-06-01T16:12:20+02:00"}
2024-06-08T16:12:20+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-06-08T17:10:52+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-08T17:10:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-08T17:10:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "dateBefore": "2024-06-01T17:10:53+02:00"}
2024-06-08T17:10:53+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-06-08T20:08:11+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
retain
2024-06-05T00:35:47+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:59Z", "Filter Size": 3851836, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-05T17:42:55+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:59Z", "Filter Size": 4667513, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-05T17:54:41+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 394229, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 11527709, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "17h18m53.962037462s", "Retain Status": "enabled"}
2024-06-05T21:00:53+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-01T17:59:59Z", "Filter Size": 867872, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-05T21:17:16+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 19771, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 1511446, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Duration": "16m22.513052224s", "Retain Status": "enabled"}
2024-06-05T21:44:27+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 378997, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 9571934, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "4h1m32.065656488s", "Retain Status": "enabled"}
2024-06-06T07:42:37+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-01T17:59:59Z", "Filter Size": 4729727, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-06T13:53:03+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-02T17:59:59Z", "Filter Size": 215507, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-06T13:57:25+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 11918, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 405604, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "4m21.479618947s", "Retain Status": "enabled"}
2024-06-07T07:28:53+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 942225, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 15520446, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "23h46m15.935124602s", "Retain Status": "enabled"}
collector
2024-06-09T00:55:51+02:00 INFO collector collect {"Process": "storagenode", "count": 1761}
2024-06-09T01:56:00+02:00 INFO collector collect {"Process": "storagenode", "count": 1632}
2024-06-09T02:55:47+02:00 INFO collector collect {"Process": "storagenode", "count": 1431}
2024-06-09T03:55:36+02:00 INFO collector collect {"Process": "storagenode", "count": 1236}
2024-06-09T04:55:25+02:00 INFO collector collect {"Process": "storagenode", "count": 1184}
2024-06-09T05:55:42+02:00 INFO collector collect {"Process": "storagenode", "count": 1168}
2024-06-09T06:56:16+02:00 INFO collector collect {"Process": "storagenode", "count": 1107}
2024-06-09T07:55:28+02:00 INFO collector collect {"Process": "storagenode", "count": 1014}
2024-06-09T08:56:00+02:00 INFO collector collect {"Process": "storagenode", "count": 1150}
2024-06-09T09:55:55+02:00 INFO collector collect {"Process": "storagenode", "count": 1242}
2024-06-09T10:55:55+02:00 INFO collector collect {"Process": "storagenode", "count": 1286}
2024-06-09T11:56:21+02:00 INFO collector collect {"Process": "storagenode", "count": 1463}
2024-06-09T12:55:55+02:00 INFO collector collect {"Process": "storagenode", "count": 1313}
2024-06-09T13:56:25+02:00 INFO collector collect {"Process": "storagenode", "count": 2005}
tash
2024-06-08T15:55:00+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-08T16:08:55+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "13m55.68524297s"}
2024-06-08T16:08:55+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-08T16:12:20+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "3m24.317672127s"}
2024-06-08T16:12:20+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-08T17:10:53+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "58m33.026651803s"}
2024-06-08T17:10:53+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-08T20:08:12+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "2h57m19.173461553s"}
Node 2:
2024-05-19T05:47:20+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-19T05:47:20+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-19T05:47:20+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-19T05:47:33+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-19T05:47:33+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-19T05:47:33+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-19T05:48:43+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-19T05:48:43+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-19T05:48:43+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-05-19T05:48:43+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-05-19T06:36:54+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-19T06:36:54+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-19T06:36:54+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-05-19T06:36:54+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-05-19T06:41:04+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-19T06:41:04+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-05-19T06:41:05+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-05-19T06:41:05+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-05-19T06:42:20+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
GC filewalker
2024-06-09T05:47:33+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-09T05:47:33+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-06-02T05:47:33+02:00"}
2024-06-09T05:47:33+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-06-09T05:47:33+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-09T05:47:33+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-09T05:47:33+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "dateBefore": "2024-06-02T05:47:33+02:00"}
2024-06-09T05:47:33+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-06-09T10:53:54+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-09T10:53:55+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-09T10:53:55+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "dateBefore": "2024-06-02T10:53:55+02:00"}
2024-06-09T10:53:55+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-06-09T10:59:12+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-09T10:59:12+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-09T10:59:12+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-06-02T10:59:12+02:00"}
2024-06-09T10:59:12+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-06-09T10:59:12+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
retain
2024-06-05T04:11:13+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:59Z", "Filter Size": 3846327, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-05T21:36:13+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:59Z", "Filter Size": 8668127, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-05T23:14:46+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-01T17:59:59Z", "Filter Size": 1198838, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-05T23:49:33+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 20210, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 2067376, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Duration": "34m47.034499133s", "Retain Status": "enabled"}
2024-06-06T02:44:07+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 342228, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 11761293, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "22h32m54.060050423s", "Retain Status": "enabled"}
2024-06-06T03:02:17+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 455888, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 16397018, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "5h26m3.936115611s", "Retain Status": "enabled"}
2024-06-06T08:18:01+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-02T17:59:59Z", "Filter Size": 264157, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-06T08:30:05+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 12691, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 482907, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "12m3.594219038s", "Retain Status": "enabled"}
2024-06-06T10:09:35+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-01T17:59:59Z", "Filter Size": 4689231, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-07T08:10:13+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 952182, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 14215384, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "22h0m38.211402428s", "Retain Status": "enabled"}
collector
2024-06-09T00:49:03+02:00 INFO collector collect {"Process": "storagenode", "count": 1772}
2024-06-09T01:49:05+02:00 INFO collector collect {"Process": "storagenode", "count": 1694}
2024-06-09T02:48:44+02:00 INFO collector collect {"Process": "storagenode", "count": 1503}
2024-06-09T03:48:37+02:00 INFO collector collect {"Process": "storagenode", "count": 1274}
2024-06-09T04:47:47+02:00 INFO collector collect {"Process": "storagenode", "count": 1183}
2024-06-09T05:48:27+02:00 INFO collector collect {"Process": "storagenode", "count": 1133}
2024-06-09T06:48:44+02:00 INFO collector collect {"Process": "storagenode", "count": 1038}
2024-06-09T07:49:02+02:00 INFO collector collect {"Process": "storagenode", "count": 1098}
2024-06-09T08:48:40+02:00 INFO collector collect {"Process": "storagenode", "count": 1178}
2024-06-09T09:48:48+02:00 INFO collector collect {"Process": "storagenode", "count": 1245}
2024-06-09T10:48:55+02:00 INFO collector collect {"Process": "storagenode", "count": 1321}
2024-06-09T11:48:57+02:00 INFO collector collect {"Process": "storagenode", "count": 1444}
2024-06-09T12:48:28+02:00 INFO collector collect {"Process": "storagenode", "count": 1353}
2024-06-09T13:48:51+02:00 INFO collector collect {"Process": "storagenode", "count": 1919}
tash
2024-06-09T05:47:33+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-09T05:47:33+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "133.021788ms"}
2024-06-09T05:47:33+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-09T10:53:55+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "5h6m21.839974608s"}
2024-06-09T10:53:55+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-09T10:59:12+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "5m16.460473007s"}
2024-06-09T10:59:12+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-09T10:59:12+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "92.855859ms"}
Node 3:
2024-05-17T03:32:06+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-17T03:32:06+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-05-17T03:32:06+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-05-17T04:03:36+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-17T04:03:36+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-17T04:03:36+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-05-17T04:03:36+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-05-17T04:07:05+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-17T04:07:05+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-05-17T04:07:05+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-05-17T04:07:05+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-05-17T04:07:54+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-05-17T04:07:54+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-17T04:07:54+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-17T04:07:54+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-05-17T04:08:26+02:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
GC filewalker
2024-06-09T03:32:06+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-09T03:32:06+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-06-02T03:32:06+02:00"}
2024-06-09T03:32:06+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-06-09T03:32:06+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-09T03:32:06+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-09T03:32:06+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "dateBefore": "2024-06-02T03:32:06+02:00"}
2024-06-09T03:32:06+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-06-09T06:24:40+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-09T06:24:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-09T06:24:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "dateBefore": "2024-06-02T06:24:41+02:00"}
2024-06-09T06:24:41+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-06-09T06:32:08+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-09T06:32:08+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-09T06:32:08+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-06-02T06:32:08+02:00"}
2024-06-09T06:32:08+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-06-09T06:32:08+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
retain
2024-06-03T15:54:21+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:59Z", "Filter Size": 984041, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-03T16:15:20+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 61183, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 1759322, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Duration": "20m58.788550977s", "Retain Status": "enabled"}
2024-06-03T18:30:06+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:58Z", "Filter Size": 235857, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-03T18:32:14+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 9244, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 416218, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "2m7.843759921s", "Retain Status": "enabled"}
2024-06-03T19:24:00+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-28T17:59:59Z", "Filter Size": 8019635, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-03T23:40:15+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 312997, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 15212976, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "4h16m14.471667689s", "Retain Status": "enabled"}
2024-06-05T06:10:30+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:59Z", "Filter Size": 3905357, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-05T23:09:46+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-05-30T17:59:59Z", "Filter Size": 8196159, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-06T06:17:05+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-01T17:59:59Z", "Filter Size": 1012040, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-06T06:56:02+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 23460, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 1771179, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Duration": "38m57.081998781s", "Retain Status": "enabled"}
2024-06-06T09:27:36+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 390862, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 15614833, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "10h17m49.478379286s", "Retain Status": "enabled"}
2024-06-06T13:13:09+02:00 INFO retain Prepared to run a Retain request. {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-06-02T17:59:59Z", "Filter Size": 245109, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-06T13:24:40+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 11198, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 450548, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "11m30.969742055s", "Retain Status": "enabled"}
2024-06-07T03:20:52+02:00 INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 332898, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 13197286, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "45h10m22.131314034s", "Retain Status": "enabled"}
collector
2024-06-09T00:34:02+02:00 INFO collector collect {"Process": "storagenode", "count": 1885}
2024-06-09T01:33:53+02:00 INFO collector collect {"Process": "storagenode", "count": 1766}
2024-06-09T02:33:56+02:00 INFO collector collect {"Process": "storagenode", "count": 1545}
2024-06-09T03:34:01+02:00 INFO collector collect {"Process": "storagenode", "count": 1351}
2024-06-09T04:33:09+02:00 INFO collector collect {"Process": "storagenode", "count": 1254}
2024-06-09T05:32:58+02:00 INFO collector collect {"Process": "storagenode", "count": 1124}
2024-06-09T06:33:29+02:00 INFO collector collect {"Process": "storagenode", "count": 1099}
2024-06-09T07:33:29+02:00 INFO collector collect {"Process": "storagenode", "count": 1034}
2024-06-09T08:34:08+02:00 INFO collector collect {"Process": "storagenode", "count": 1067}
2024-06-09T09:33:37+02:00 INFO collector collect {"Process": "storagenode", "count": 1268}
2024-06-09T10:33:30+02:00 INFO collector collect {"Process": "storagenode", "count": 1270}
2024-06-09T11:33:45+02:00 INFO collector collect {"Process": "storagenode", "count": 1425}
2024-06-09T12:34:08+02:00 INFO collector collect {"Process": "storagenode", "count": 1499}
2024-06-09T13:33:40+02:00 INFO collector collect {"Process": "storagenode", "count": 1507}
2024-06-09T14:34:44+02:00 INFO collector collect {"Process": "storagenode", "count": 2232}
tash
2024-06-09T03:32:06+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-09T03:32:06+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "129.783411ms"}
2024-06-09T03:32:06+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-09T06:24:41+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "2h52m34.90877659s"}
2024-06-09T06:24:41+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-09T06:32:08+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "7m26.528612778s"}
2024-06-09T06:32:08+02:00 INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-09T06:32:08+02:00 INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "92.254008ms"}
I don’t think anything is wrong, they just haven’t been sent out since 06-06.
Hopefully they’ll tune the capacity-reservation uploads to be relatively smooth: so we reach a steady-state of uploads+deletes most days. Because you’re right: if our bursty ingress inevitably results in days with massive deletes… the tears will be legendary! ![]()
No matter what Storj does… someone will come here to complain… even if it’s making them money…
Meanwhile I checked my incoming test data. It seems to be always 30 day TTL, so this will disapear at the same speed it is coming in.
Why would they? Nobody will expect this kind of tuning from regular customers.
Capacity-reservation ingress isn’t performance-testing or customer-workload simulation. It’s the least-impactful way to keep space saved. The easiest way to do that is to upload at a slow constant rate: so each day the same amount of TTL data is deleted as is uploaded.
Why would they upload at anything above the bare-minimum rate? It would just be stealing potential performance from paying customers… and SNOs complain more as upload+deletes become more variable.
The same as usual - do, please, nothing.
You do not need to change anything. The short message - “do not do anything, unless you are sure about taxes”.
