So as you can see I couldn’t make an appropriate title
I have a suggestion, I personally have multiple nodes and it would be great to have a website where nice operators would enter their address and it will show their undistributed payout.
http://localhost:14002/payout-information
Take a look on Balance section
For remote connect: How to remote access the web dashboard - Node Operator
Yes I’m aware of both, but what my suggestion is to make a centralized location where all of these numbers are added up together
It was mentioned elsewhere that this will be part of the multinode dashboard that will eventually replace the normal dashboard. So it’s being worked on.
