Database disk is malformed
Yes, only those malformed should be fixed.
I updated an article, you should not see errors anymore when you load the data.
I got ok on the bandwith database.
Got error right away when i start to load the orders.db and the database is 0kb
/data # sqlite3 /storage/orders.db “.read /storage/dump_all_notrans.sql”
Error: near line 9: cannot commit - no transaction is active
I also tried to start the node and i got a new error in the log:
2020-04-01T09:56:33.672Z INFO db.migration.27 Add index archived_at to ordersDB
Error: Error creating tables for master database on storagenode: migrate: no such table: main.order_archive_
storj.io/storj/private/migrate.SQL.Run:251
storj.io/storj/private/migrate.(*Migration).Run.func1:171
storj.io/storj/private/dbutil/txutil.withTxOnce:67
storj.io/storj/private/dbutil/txutil.WithTx:36
storj.io/storj/private/migrate.(*Migration).Run:170
storj.io/storj/storagenode/storagenodedb.(*DB).CreateTables:285
main.cmdRun:188
storj.io/storj/pkg/process.cleanup.func1.2:312
storj.io/storj/pkg/process.cleanup.func1:330
github.com/spf13/cobra.(*Command).execute:826
github.com/spf13/cobra.(*Command).ExecuteC:914
github.com/spf13/cobra.(*Command).Execute:864
storj.io/storj/pkg/process.ExecWithCustomConfig:84
storj.io/storj/pkg/process.ExecCustomDebug:66
main.main:328
runtime.main:203
  1. Stop the storagenode
  2. Execute:
CREATE TABLE unsent_order (
                                                satellite_id  BLOB NOT NULL,
                                                serial_number BLOB NOT NULL,
                                                order_limit_serialized BLOB      NOT NULL, -- serialized pb.OrderLimit
                                                order_serialized       BLOB      NOT NULL, -- serialized pb.Order
                                                order_limit_expiration TIMESTAMP NOT NULL, -- when is the deadline for s
ending it
                                                uplink_cert_id INTEGER NOT NULL,
                                                FOREIGN KEY(uplink_cert_id) REFERENCES certificate(cert_id)
CREATE TABLE order_archive_ (
                                                status      INTEGER   NOT NULL,
                                                archived_at TIMESTAMP NOT NULL,
CREATE UNIQUE INDEX idx_orders ON unsent_order(satellite_id, serial_number);
CREATE TABLE versions (version int, commited_at text);
CREATE INDEX idx_order_archived_at ON order_archive_(archived_at);
.exit
  1. Try to start the storagenode
SQLite version 3.30.1 2019-10-10 20:19:45
Enter “.help” for usage hints.
sqlite> CREATE TABLE unsent_order (
…> satellite_id BLOB NOT NULL,
…> serial_number BLOB NOT NULL,
…> order_limit_serialized BLOB NOT NULL, – serialized pb.OrderLimit
…> order_serialized BLOB NOT NULL, – serialized pb.Order
…> order_limit_expiration TIMESTAMP NOT NULL, – when is the deadline for sending it
…> uplink_cert_id INTEGER NOT NULL,
…> FOREIGN KEY(uplink_cert_id) REFERENCES certificate(cert_id)
sqlite> CREATE TABLE order_archive_ (
…> status INTEGER NOT NULL,
…> archived_at TIMESTAMP NOT NULL,
sqlite> CREATE UNIQUE INDEX idx_orders ON unsent_order(satellite_id, serial_number);
sqlite> CREATE TABLE versions (version int, commited_at text);
Error: table versions already exists
sqlite> CREATE INDEX idx_order_archived_at ON order_archive_(archived_at);
sqlite> .exit
Storjlog:
2020-04-01T20:43:16.301Z INFO db.migration.27 Add index archived_at to ordersDB
Error: Error creating tables for master database on storagenode: migrate: index idx_order_archived_at already exists
main.cmdRun:188
main.main:328
runtime.main:203
  2. Execute
DROP INDEX idx_order_archived_at;
.exit
Ah it finally started. Thanks.
How can i avoid to get malformed in the future if i’m going to continue using unraid?
Either update to the latest version of the Unraid (it’s fixed in the 6.8.0-rc5 as seen in this comment) or downgrade it to the 6.6.7
Ok. I’m running 6.8.3 so i should be fine
