Thank you, for your time !
The default value needs to be tested by yourself. What is suitable for me is that I set the error rate to 40% in the default 7 setting, and adjust it to 120, and the error tolerance rate is 90%.
We no longer use a default setting for concurrency, this has been removed by a recent release. You should not have to worry about concurrency now unless you are running your node on a device like a raspberry Pi which could get overloaded by too many concurrent requests. This does not seem to be the case for you, so please comment out any line specifying concurrency now.
