Sorry, I can’t download from there, it’s blocked in my country ![]()
I’ll just point to this source… I think you’ll agree that he would probably know.
He posted some more responses on that topic hinting you may be sorry if you exited the satellite.
For that reason I created a new node. Should stefan-benten not reset the GEed nodes, then I will use that node just for his satellite.
Sounded to me like the better solution than risking multiple hundred USD in held back (even though they will be paid when stefan-benten resets/shuts down but we keep hearing that since at least 6 months so I stopped relying on that information…)
Nothing strange. More exited nodes, less reliable nodes that ready to receive data. Node list from satellite is full of rubish now. I failed second GE and ready to catch a few more
yeah that sounds like a problem lately… My GE has been 4 months ago. But now we should wait for a fix with the next release.
It’s good that everyone understands that the problem is not mine.
In order for me to re-run the output, you must unlock my node.
Will you cancel the disqualification?
We are actively working on a fix for this issue. Please create a support ticket if you have not already done so, so we can track your issue. Once the fix is deployed we will remove the disqualification for nodes that were incorrectly disqualified. In the meantime, please refrain from initiating any graceful exits.
Hopefully google does’nt restrict countries, try this link https://drive.google.com/file/d/1QEHDDYDEywltCKRJFwQDE5j91FQk11eS/view?usp=sharing
That’s only half the problem…
Post it on IPFS, and then it can’t be restricted…
https://hardbin.com/ipfs/QmWD2J7oRBQaHSa3d4poZAcXcrUxw9LUQ78Ft9n6Gv5ksi/
- Select “New”
- The IPFS address of the document can be retrieved and viewed on any public IPFS gateway:
Yes, thank you! I got the file.
But can be lost. I saw so many corrupted links…
@anon27637763 For the same you can use the simple https://alpha.transfer.sh , which is backed by Tardigrade.
support ticket Id #6040
I have all nodes updated to version 1.9.5
I have a lot of node that work with all satellites and have more than 40 Terabytes of free space.
Please unlock my node, I want to redo the graceful exit
As I was pointed out, the DQ error during GE is not resolved in 1.9.5
So, I’ll update this thread when it is actually would be fixed
The update on the problem so far:
I’m sure my nodes are okay.
I have 100% audits, new drives.
All nodes have been updated.
storagenode version 1.10.1 (latest)
Will you unblock me so that I can gracefully exit?
In such case your node would not be DQ during GE… So, seems it has some corrupted pieces and this is enough to do not finish it…
so unblock me!
I tell you about this all the time and tell you that I have new drives, are in the servers, I am confident in the integrity of the data. I attached logs where everything indicates that everything is fine with me.
Please again - unlock so I can make an elegant exit !!!
When will you unlock me so I can gracefully exit?
I have no answer from team yet.
