ID 1gqZfYf868fWSx4Mv7GcxqPnUrYDMWzevQTWLHiySb3XJmURpi
Status ONLINE
Uptime 13m14s
Available Used Egress Ingress
Bandwidth N/A 0 B 0 B 0 B (since May 1)
Disk 6.39 TB 613.91 GB
Internal 127.0.0.1:7778
External xxxxx:28967
2022-05-23T15:31:15.124Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.55.1"}
2022-05-23T15:31:15.124Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2022-05-23T15:31:15.147Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2022-05-23T15:31:15.147Z INFO Operator email {"Process": "storagenode", "Address": "xxxxx"}
2022-05-23T15:31:15.147Z INFO Operator wallet {"Process": "storagenode", "Address": "0x7106dee8176fa63efbdf5c5946ab1452f90c06c7"}
2022-05-23T15:31:15.597Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.55.1"}
2022-05-23T15:31:15.597Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2022-05-23T15:31:15.606Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.55.1"}
2022-05-23T15:31:15.606Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2022-05-23T15:31:15.723Z INFO Telemetry enabled {"Process": "storagenode", "instance ID": "1gqZfYf868fWSx4Mv7GcxqPnUrYDMWzevQTWLHiySb3XJmURpi"}
2022-05-23T15:31:15.740Z INFO db.migration Database Version {"Process": "storagenode", "version": 53}
2022-05-23T15:31:15.834Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"Process": "storagenode"}
2022-05-23T15:31:16.573Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"Process": "storagenode"}
2022-05-23 15:31:16,574 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-05-23 15:31:16,574 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-05-23 15:31:16,574 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-05-23T15:31:16.573Z INFO Node 1gqZfYf868fWSx4Mv7GcxqPnUrYDMWzevQTWLHiySb3XJmURpi started {"Process": "storagenode"}
2022-05-23T15:31:16.573Z INFO Public server started on [::]:28967 {"Process": "storagenode"}
2022-05-23T15:31:16.574Z INFO Private server started on 127.0.0.1:7778 {"Process": "storagenode"}
2022-05-23T15:31:17.178Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "7h29m13.513553599s"}
2022-05-23T15:31:17.180Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
Your node is disqualified for losing data on almost all satellites. On the last remained satellite it’s suspended.
Looks like a catastrophic data loss.
Do you know what’s happened? Did you have any hardware problems or power loss, or maybe you deleted some data by accident?
