Does anyone know what the difference is between using “volume” and “mount type=bind,source=”?
Storj says “mount type=bind,source=” should be used, but many people use volume, what might affect the node?
Thank you
Thank you
Feels like you should have typed that exact title elsewhere
Would you look at that, there is even a specific link to a docker documentation page with a deep link to the right section.
Here you go: Use bind mounts | Docker Documentation
In the context of a storagenode though, volumes are dangerous. Since it doesn’t throw an error if your storage location isn’t available, but instead starts with no data and stores new data inside the container. This would lead to VERY quick disqualification.
