Docker invalid mount config for type "bind"
This is it:
jamcom2@jamcom2:~$ ls -la /
total 3063904
drwxr-xr-x  22 root root       4096 Mar 28 18:12 .
drwxr-xr-x  22 root root       4096 Mar 28 18:12 ..
drwxr-xr-x   2 root root       4096 Mar 28 18:12 .cache
drwxrwxrwx   5 root root       4096 Apr 15 12:33 JamCom2files
lrwxrwxrwx   1 root root          7 Feb  1 18:20 bin -> usr/bin
drwxr-xr-x   3 root root       4096 Apr 15 12:17 boot
drwxr-xr-x   2 root root       4096 Mar  6 14:37 cdrom
drwxr-xr-x  21 root root       4640 Apr 15 19:33 dev
drwxr-xr-x 144 root root      12288 Apr 14 11:44 etc
drwxr-xr-x   3 root root       4096 Mar  6 14:57 home
lrwxrwxrwx   1 root root          7 Feb  1 18:20 lib -> usr/lib
lrwxrwxrwx   1 root root          9 Feb  1 18:20 lib32 -> usr/lib32
lrwxrwxrwx   1 root root          9 Feb  1 18:20 lib64 -> usr/lib64
lrwxrwxrwx   1 root root         10 Feb  1 18:20 libx32 -> usr/libx32
drwx------   2 root root      16384 Mar  6 14:35 lost+found
drwxr-xr-x   3 root root       4096 Mar  7 15:00 media
drwxr-xr-x   4 root root       4096 Apr  4 12:12 mnt
drwxr-xr-x   3 root root       4096 Mar 28 13:01 opt
dr-xr-xr-x 242 root root          0 Apr 15 19:31 proc
drwx------   7 root root       4096 Apr  4 12:18 root
drwxr-xr-x  36 root root       1100 Apr 15 19:33 run
lrwxrwxrwx   1 root root          8 Feb  1 18:20 sbin -> usr/sbin
drwxr-xr-x   8 root root       4096 Mar  6 14:59 snap
drwxr-xr-x   2 root root       4096 Feb  1 18:20 srv
-rw-------   1 root root 3137339392 Mar  6 14:40 swap.img
dr-xr-xr-x  13 root root          0 Apr 15 19:31 sys
drwxrwxrwt  21 root root       4096 Apr 15 21:12 tmp
drwxr-xr-x  15 root root       4096 Apr 14 11:44 usr
drwxr-xr-x  14 root root       4096 Mar  7 14:32 var
jamcom2@jamcom2:~$
Apparently everything is owned by root, but I can write and read no problem, and also why docker runs with sudo just in case.
That is why all my docker commands are run with sudo privileges. If not I would had had to create a new user just for docker with all permissions as the docker guide suggests but I chose the easy path of just using sudo.
ls -la /JamCom2files/Storj/ID
Thanks peem here is the output
total 32
drwxrwxr-x 2 jamcom2 jamcom2 4096 Apr 15 19:42 .
drwxrwxrwx 4 root    root    4096 Apr 15 12:33 ..
-rw-r--r-- 1 jamcom2 jamcom2  558 Mar  7 15:02 ca.1615125777.cert
-rw-r--r-- 1 jamcom2 jamcom2 1088 Mar  7 15:02 ca.cert
-rw------- 1 jamcom2 jamcom2  241 Mar  6 21:39 ca.key
-rw-r--r-- 1 jamcom2 jamcom2 1096 Mar  7 15:02 identity.1615125777.cert
-rw-r--r-- 1 jamcom2 jamcom2 1626 Mar  7 15:02 identity.cert
-rw------- 1 jamcom2 jamcom2  241 Mar  6 21:39 identity.key
jamcom2@jamcom2:~$
sudo chown -R root:users /JamCom2files
Done but it still complaints about the binding error :tired_face:
Looks like a snap version of the docker. If so, please, uninstall it and install a normal docker-ce instead
Thank you for solution (uninstall all docker unofficial clone like snap and so on) - I’t works
