Hello,
Trying to run the node, but getting this error:
docker: Error response from daemon: driver failed programming external connectivity on endpoint storagenode (f67…b47): Error starting userland proxy: listen tcp 0.0.0.0:14450: bind: address already in use.
This port is not found in ‘netstat’ , no service is using it. I’ve looked at all topics in the forum, have not found a solution.
‘df -h’ shows 1% used on my share,
‘docker logs --tail 20 storagenode’ does not show anything, just goes as ‘enter’ to the new line.
any ideas?
thank you.
