So, I spent the evening working on getting node data into my grafana instance, I seem to have an issue no matter which way I import the template that the database isn’t linked correctly even though it is specified.
Instead I get dummy data. This happens even though the database is specified and the problem appears for some though not all panels. Some of the panels work perfectly fine - so it is seeing SOME data.
I’m using this dashboard:
Anyone else seen this? Zabbix next.
