Error creting node with docker and rpi 4b
-p 28967:28967
-p 127.0.0.1:14002:14002
-e WALLET=“0”
-e EMAIL="@"
-e ADDRESS=“4:28967”
-e STORAGE=“1TB”
–mount type=bind,source="/home/pi/storagenode",destination=/app/identity
–mount type=bind,source="/mnt/storj",destination=/app/config
ls /home/pi/storagenode
ca.1593546352.cert ca.key identity.cert
ca.cert identity.1593546352.cert identity.key
OK
and
ls /mnt/storj
pi@raspberrypi:~ $ ls /mnt/storj
config.yaml lost+found
and
mount /dev/sda2
according to the log, the container is still restarting?
mount: /mnt/storj: /dev/sda1 already mounted on /mnt/storj.
thanks for all the time you are spending to help me
not one “-” only two “–”
see at: Storage Node - Storj Docs
like this?
-p 28967:28967
-e WALLET=“0c5”
-e EMAIL=“s”
-e ADDRESS=“22:28967”
-e STORAGE=“900GB”
docker give me this error
docker: invalid reference format.
See ‘docker run --help’.
@Gerarardit are you running the command as a single line?
“docker run -d --restart unless-stopped --stop-timeout 300 -p 28967:28967 -p 127.0.0.1:14002:14002 …”?
OR
"docker run -d --restart unless-stopped --stop-timeout 300 \
-p 28967:28967 \
-p 127.0.0.1:14002:14002 \ … etc?
Seems you have used some wordprocessor. It replaced all -- to hyphens.
Please, replace them back to --
Also, replace all curly quotes “ and ” to the straight ones "
Use only plain text editor, nano or vi for example
It’s on different lines
Is this working now? The docker run command can be run either a single line or different lines using a ‘\’ after each line except the last.
