6 posts were split to a new topic: ERROR piecestore:cache error getting current space used calculation: {“error”: “context canceled”}
I removed bandwidth.db as it was a copy of orders.db
I didn’t find bandwidth.db before doing cp command so I don’t make a backup.
I started docker and bandwidth.db was created but empty - no tables when I run .tables
And I receive this error:
Error: Error during preflight check for storagenode databases: storage node preflight database error: bandwidth: expected schema does not match actual: &dbschema.Schema{
Tables: []*dbschema.Table{
Columns: []*dbschema.Column{
&{Name: "action", Type: "INTEGER"},
&{Name: "amount", Type: "BIGINT"},
&{Name: "created_at", Type: "TIMESTAMP"},
&{Name: "satellite_id", Type: "BLOB"},
&{Name: "interval_start", Type: "TIMESTAMP"},
PrimaryKey: []string{"action", "interval_start", "satellite_id"},
+ Tables: nil,
Indexes: []*dbschema.Index{
Table: "bandwidth_usage",
Columns: []string{"created_at"},
Columns: []string{"satellite_id"},
+ Indexes: nil,
storj.io/storj/storagenode/storagenodedb.(*DB).Preflight:317
main.cmdRun:196
storj.io/storj/pkg/process.cleanup.func1.2:299
storj.io/storj/pkg/process.cleanup.func1:317
github.com/spf13/cobra.(*Command).execute:826
github.com/spf13/cobra.(*Command).ExecuteC:914
github.com/spf13/cobra.(*Command).Execute:864
storj.io/storj/pkg/process.ExecWithCustomConfig:79
storj.io/storj/pkg/process.Exec:61
main.main:326
runtime.main:203
sqlite3 bandwidth.db
CREATE TABLE bandwidth_usage (
satellite_id BLOB NOT NULL,
action INTEGER NOT NULL,
amount BIGINT NOT NULL,
created_at TIMESTAMP NOT NULL
CREATE TABLE bandwidth_usage_rollups (
interval_start TIMESTAMP NOT NULL,
PRIMARY KEY ( interval_start, satellite_
id, action )
CREATE INDEX idx_bandwidth_usage_satellite ON bandwidth_usage(satellite_id);
CREATE INDEX idx_bandwidth_usage_created ON bandwidth_usage(created_at);
.exit
It worked! Thank you!
Hi, can you please help me? I have problems with bandwidth.db file during starting storagenode. At first it get me error about the file bandwidth.db is not a database, then I tried to resolve the issue using this:
This is not fix the issue, because there is no error inside the database. Then I tried to delete the file and start storagenode again, but i get this error:
Error: Error during preflight check for storagenode databases: preflight: database “bandwidth”: expected schema does not match actual: &dbschema.Schema{
Tables: []*dbschema.Table{ -
s""" -
Columns: -
Type: INTEGER -
Nullable: false -
Default: "" -
Reference: nil -
Type: BIGINT -
Nullable: false -
Default: "" -
Reference: nil -
Type: TIMESTAMP -
Nullable: false -
... // 10 elided lines -
s""" -
s""" -
Columns: -
Type: INTEGER -
Nullable: false -
Default: "" -
Reference: nil -
Type: BIGINT -
Nullable: false -
Default: "" -
Reference: nil -
Type: TIMESTAMP -
Nullable: false -
s""" -
Tables: nil,
Indexes: []*dbschema.Index{ -
s`Index<Table: bandwidth_usage, Name: idx_bandwidth_usage_created, Columns: created_at, Unique: false, Partial: "">`, -
s`Index<Table: bandwidth_usage, Name: idx_bandwidth_usage_satellite, Columns: satellite_id, Unique: false, Partial: "">`, -
Indexes: nil,}
storj.io/storj/storagenode/storagenodedb.(*DB).preflight:405 storj.io/storj/storagenode/storagenodedb.(*DB).Preflight:352 main.cmdRun:208 storj.io/private/process.cleanup.func1.4:363 storj.io/private/process.cleanup.func1:381 github.com/spf13/cobra.(*Command).execute:842 github.com/spf13/cobra.(*Command).ExecuteC:950 github.com/spf13/cobra.(*Command).Execute:887 storj.io/private/process.ExecWithCustomConfig:88 storj.io/private/process.ExecCustomDebug:70 main.main:385 runtime.main:204
Hello @mravac ,
Please,
- Stop the storagenode
- Remove
bandwidth.db - Move all
*.dbto the different folder - Start storagenode
It should create all databases, but they will be empty. - Stop the storagenode
- Move all backed up databases back with replace
- Start storagenode
- Check your logs
