Hi. I have a node on a raspberry pi 4 with 1TB working properly. Today I have put a second disk with 2TB, which I have mounted exactly the same as the first except that I have changed the ports. I have an error in this second node which in the log shows me: Got a signal from the OS: “terminated”
Error: debug: http: Server closed What could be the cause of this error and how to solve it so that the node is Online? Thank you
> sudo docker logs --tail 20 nodo1
> 2020-09-08T14:12:01.628Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
> 2020-09-08T14:12:01.628Z INFO bandwidth Performing bandwidth usage rollups
> 2020-09-08T14:12:01.629Z INFO Node 1hBbdAp6UjmxAiN8AnTnwNsJEnRsXpfTPVoUeMeQ5PQQw4mdhQ started
> 2020-09-08T14:12:01.629Z INFO Public server started on [::]:28967
> 2020-09-08T14:12:01.629Z INFO Private server started on 127.0.0.1:7778
> 2020-09-08T14:12:01.629Z INFO trust Scheduling next refresh {"after": "6h52m59.090345583s"}
> 2020-09-08T14:20:39.947Z INFO Got a signal from the OS: "terminated"
> 2020-09-08T14:24:20.920Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
> 2020-09-08T14:24:20.940Z INFO Operator email {"Address": "@macronukes.com"}
> 2020-09-08T14:24:20.940Z INFO Operator wallet {"Address": "0x7"}
> 2020-09-08T14:24:22.062Z INFO Telemetry enabled
> 2020-09-08T14:24:22.102Z INFO db.migration Database Version {"version": 43}
> 2020-09-08T14:24:23.630Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
> 2020-09-08T14:24:24.513Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
> 2020-09-08T14:24:24.513Z INFO bandwidth Performing bandwidth usage rollups
> 2020-09-08T14:24:24.516Z INFO trust Scheduling next refresh {"after": "5h20m29.829853535s"}
> 2020-09-08T14:24:24.518Z INFO Node 1hBbdAp6UjmxAiN8AnTnwNsJEnRsXpfTPVoUeMeQ5PQQw4mdhQ started
> 2020-09-08T14:24:24.519Z INFO Public server started on [::]:28967
> 2020-09-08T14:24:24.521Z INFO Private server started on 127.0.0.1:7778
