All seems that it is network issue.
When trying to telnet to hosts from logs to port 7777 or other, no response.
Same telnet from other servers works.
However, no changes on server made since that happened.
Checked with network provider, confirmed that no changes or any traffic blocked from their side.
Disabled all other services (including firewall) with no luck.
I can ping target IP, but can’t connect to any of the services.
at this stage I ran out of ideas what else to check as system logs show nothing unusual.
only thing now is to reinstall OS
Here are starting logs, basically showing that can’t communicate with remote nodes on port 7777:
2021-03-31T06:30:27.966Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-03-31T06:30:27.985Z INFO Operator email {"Address": "XXXXXX"}
2021-03-31T06:30:27.986Z INFO Operator wallet {"Address": "XXXXXX"}
2021-03-31T06:31:03.117Z INFO Telemetry enabled {"instance ID": "XXXXXX"}
2021-03-31T06:31:03.202Z INFO db.migration Database Version {"version": 51}
2021-03-31T06:31:18.958Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-03-31T06:31:38.958Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMu
awymB", "error": "rpc: dial tcp 35.228.10.185:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 35.228.10.185:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.Dia
lContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeURL
.func1:101\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:87\n\tstorj.io/common/rpc.Dialer.dialPool:146\n\tstorj.io/common/rpc.Dialer.DialNodeURL:100\n\tstorj.io/storj/stor
agenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:
57"}
2021-03-31T06:31:38.959Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3
vzoA6", "error": "rpc: dial tcp 35.194.133.253:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 35.194.133.253:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.D
ialContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeU
RL.func1:101\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:87\n\tstorj.io/common/rpc.Dialer.dialPool:146\n\tstorj.io/common/rpc.Dialer.DialNodeURL:100\n\tstorj.io/storj/st
oragenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func
1:57"}
2021-03-31T06:31:38.959Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwm
cNDDs", "error": "rpc: dial tcp 35.205.38.124:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 35.205.38.124:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.Dia
57"}
