Error when migrate node - Lose data used
I have node with more than 6TB downloaded. I migrated my node to other pc. But when start I saw Used => 0MB.
Please help me :frowning:
@Alexey Help me please
Hi @s1248.com
If your node is running fine, i.e without errors, and the only issue is the dashboard display of data used then you probably didn’t migrate your database files. The list of files should be:
bandwidth.db
heldamount.db
info.db
notifications.db
orders.db
piece_expiration.db
piece_spaced_used.db
pieceinfo.db
pricing.db
reputation.db
satellites.db
secret.db
storage_usage.db
used_serial.db
I expect you didn’t stop the old node before you ran the last copy, so the db files we in use and couldn’t be copied. If the db files weren’t present then the new node would create them on first run.
I kept all file on drive. I only install storagenode.msi, follow install wizard then start node. How to fix this?
Will I lose all downloaded data? Does it affect income? Mỗi lần tôi kết nối tới dashboard, mọi con số đều trở thành 0.
It look like you haven’t lost any customer data. It is just the dashboard which did not have the old statistics. As long as you moved the blobs and orders folders fully then you will only be missing some statistics.
Thank you. My node is working now.
