Hello Everyone,
I am new to Storj. I find this product exciting. I came to know about this from my professor. I am successfully able to create buckets and throw some documents into it via powershell.Now i am trying to do the same thing with APIs. At storj-client-libraries, I have started with Python api.
I am stuck at Install go package of storj. I have tried on three different OS and it is giving me different erros.
Ubuntu 16.04
$ go get
storj.io/storj/lib/uplink
go/src/storj.io/storj/lib/uplink/common.go:7:2: code in directory /root/go/src/github.com/spacemonkeygo/monkit expects importgithub.com/spacemonkeygo/monkit/v3
$ go version
go version go1.12.6 linux/amd64
Windows 10
PS C:\Users> go get
#storj.io/common/rpc/rpcpool
go\src`storj.io`\common\rpc\rpcpool\pool.go:73:5: cannot use (*Conn)(nil) (type *Conn) as type drpc.Conn in assignment:
*Conn does not implement drpc.Conn (missing Closed method)
PS C:\Users\jeet-laptop> go version go version go1.14.2 windows/amd64
Debian GNU/Linux 9 (stretch)
jeet@storage-service-storj:~$ go get
Projects/Proj1/src/storj.io/common/rpc/rpcpool/pool.go:73:5: cannot use (*Conn)(nil) (type *Conn) as type drpc.Conn in assignment:
$ go version
go version go1.13.3 linux/amd64
Let me know if anyone faced similar issue.
You can try this without no set up at free-ubuntu-playground
I am new to go-lang. So help me to identify the issue.
Thanks
