I on the third attempt trying to setup my node on ubuntu and I am getting the following errors. The first one is when i run the initial docker command, and the second occurs when i run the second command(logs obtained from protainer):
Running ./storagenode setup --config-dir config --identity-dir identity --metrics.app-suffix=-alpha --metrics.interval=30m --version.server-address=https://version.storj.io --console.address=:14002 --storage.allocated-disk-space=2.0TB
2023-01-05T15:23:52.894Z INFO Anonymized tracing enabled {“Process”: “storagenode”}
Error: open /app/config/config.yaml3369685483: permission denied
— stat config/storage/temp: no such file or directory
— stat config/storage/blobs: no such file or directory
Error: Error starting master database on storagenode: group:
— stat config/storage/trash: no such file or directory
— stat config/storage/garbage: no such file or directory
2023-01-05 15:30:56,997 INFO exited: storagenode (exit status 1; not expected)
