This file do not move?
This file is not related to database. Dont move it!
Move only *.db files.
I dont use quotation marks in config file.
And now it is this error:
Can it be related what C: is system drive?
After I moved DB’s back node immidiately started
Maybe it cannot handle empty spaces in directory names?
тв now this:
2024-06-10T17:29:47Z INFO Configuration loaded {"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "healthcheck.details"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet-features"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.email"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage2.database-dir"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "contact.external-address"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "healthcheck.enabled"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.address"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.private-address"}
2024-06-10T17:29:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "console.address"}
2024-06-10T17:29:47Z INFO Anonymized tracing enabled {"Process": "storagenode-updater"}
2024-06-10T17:29:47Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2024-06-10T17:29:47Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.104.5"}
2024-06-10T17:29:47Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2024-06-10T17:29:47Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2024-06-10T17:29:47Z INFO Operator email {"Process": "storagenode", "Address": "7437493@gmail.com"}
2024-06-10T17:29:47Z INFO Operator wallet {"Process": "storagenode", "Address": "0xE158e01cDb77F9f220d8359335Fe0b75799829AA"}
This is normal info message. No errors.
I just realised you are using docker… ![]()
So your storagenode cannot access the ssd directory directly. You have to mount it in the docker start command.
Do you mean like this?
docker run -d --restart unless-stopped --stop-timeout 300 -p 192.168.4.50:28968:28967/tcp -p 192.168.4.50:28968:28967/udp -p 127.0.0.1:14004:14002 -e WALLET=“0xE158e01cDb77F9f220d8359335Fe0b75799829AA” -e EMAIL="7437493@gmail.com" -e ADDRESS=“XX.XXX.149.224:28968” -e STORAGE=“16.1TB” --mount type=bind,source=“F:\Identity\storagenode D1.6”,destination=/app/identity --mount type=bind,source=“F:\StorjD1.6”,destination=/app/config --name storagenodeD1.6 storjlabs/storagenode:latest --storage2.database-dir: C:\Storj_DB\D1.6
you need to mount C:\Storj_DB\D1.6 to the folder inside the container and use the path inside the container for the databases option, i.e.
docker run -d --restart unless-stopped --stop-timeout 300 -p 192.168.4.50:28968:28967/tcp -p 192.168.4.50:28968:28967/udp -p 127.0.0.1:14004:14002 -e WALLET="0xE158e01cDb77F9f220d8359335Fe0b75799829AA" -e EMAIL="7437493@gmail.com" -e ADDRESS="XX.XXX.149.224:28968" -e STORAGE="16.1TB" --mount type=bind,source="F:\Identity\storagenode D1.6",destination=/app/identity --mount type=bind,source="F:\StorjD1.6",destination=/app/config --mount type=bind,source=C:\Storj_DB\D1.6,destination=/app/dbs --name storagenodeD1.6 storjlabs/storagenode:latest --storage2.database-dir: dbs
You may add up:
