Hello,
I installed fail2ban. Is there any special setup regarding fail2ban to run Storj?
Or does it work out of the box?
Hello,
Is set up a node with fail2ban. An it seems to work.
there’s no reason why fail2ban would have any effect on storj.
Fail2Ban by default only monitors ssh ports when you install it. You have to manually add other services to monitor.
So under a default install, it should not affect Storj.
