I am installing storage node on CentOS 7.6, but unfortunately it doesn’t work, docker continuously restarts,
I uses “docker logs” and get following messages:
2019-12-01T12:29:54.850Z DEBUG process/debug.go:51 debug server listening on 127.0.0.1:44974
2019-12-01T12:29:54.850Z FATAL process/exec_conf.go:288 Unrecoverable error {“error”: “storagenode configuration already exists (/app/config)”}
I hope you did not ignore the comment about not using -v option. It is urgent that you update your docker run command to the correct one, and not wait for your node to crash and be lost because of this.
Once again, please do not ignore the advise about changing -v to --mount now even if just upgrading docker resolved your current issue. You may lose your entire node and data if you have an unexpected outage. Better safe than sorry …
