Hi
I updated the node 2020-05-11 after that the node doesnt find my identity.
This is what it says:
2020-05-12T05:03:42.498Z FATAL Failed to load identity. {“error”: “file or directory not found error: open identity/identity.cert: operation not permitted”, “errorVerbose”: "file or directory not found error: open identity/identity.cert: operation not
Watchtower says
time=“2020-04-10T10:01:31Z” level=info msg=“Unable to update container /storagenode. Proceeding to next.”
time=“2020-05-01T21:20:28Z” level=info msg=“Waiting for running update to be finished…”
My identity is correct.
I have read in other topics that they have made a script, is that a bat file? To show again where the identity is.
What do I need to write in the bat file? dont have a clue =)
think it was 1.3.x something with 3, the new update came the 11th for me. Dont remember what version it was.
The folder has 6 files, strange that all have worked for like 10 months and this update kills it.
Your docker container still has the “alpha” tag, it might be part of the problem. I would stop and remove the container and create it again according to the docs.
This being said, if you only have 1 node on this PC and don’t plan to have more, then I think the recommendation is to use the Windows-GUI. I can’t help you with that, because I use Linux only.
Your identity will be at C drive so if you are migrating to another HDD in same computer then you need to copy the storage folder to this new HDD. Then edit your docker run command with new path to this drive.
If you want to migrate from docker on Windows to GUI then follow this link
all look good but I need to change my diskspace, is there any easy way to do that? Or can I just uninstall and install again or do the container get deleted to?
