Filewalker status
Thank you, fixed.
But I guess you need to use a different filter anyway after the latest update:
It’s possible too, I need to wait until my nodes will update to the new version to confirm.
It disables the lazy mode for any filewalker and disables the used space filewalker for your node.
I made a post hoping this name changing will stop.
https://forum.storj.io/t/preserve-loggers-names-for-log-custom-level/25914?u=snorkel
Suggestion to add what each filewalker does and to which extent it “walks” the file? For example every filem only files in trash, only metadata or whatever.
Maybe I can edit this and start with addition from @snorkel
Thanks for adding this information to the wiki!
I can try and add more but I don’t know if I will get them all right.
I tried the above command after stopping the node, but nothing happened. Is there a way to resolve the discrepancy? Docker node…
The command above is to track the progress, it doesn’t fix anything.
Only the used-space-filewalker can fix it, but for that it should be enabled on start (it’s enabled by default) and your databases should not have any issues and you should not have any errors in your logs neither related to databases nor filewalkers.
The command will allow to see, when the filewalker is finished for each trusted satellite. When you would have all successfully finished filewalkers, they would update a database. So, there you should not have errors related to the databases. Only after that the discrepancy should be fixed.
Oh… I don’t have any other log problems at the moment, so it’ll be fine if I wait, thank you. :wink:
