Hashstore Migration Guide
Lazy people just do nothing. Alternative would be setting everything to true and then do nothing. :wink:
Yeah I think I don’t have strace on my Synology. Looked a bit around but looked complicated to install. Thanks anyway. IO is down, so I think migration is done.
Migration will be done, when the blobs subfolder will not have any files remained. Ideally, it should also delete empty subfolders.
one small node I have has 2.1GB in the blobs folder.
now I am getting.
piecemigrate:chore      all enqueued for migration; will sleep before next pooling {"process": "storagenode", "active": {"1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE": true, "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6": true, "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S": true, "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs": true}, "interval": "10m0s"}
Does this mean it finished?
Look at those files. Check logs for the messages that mention those files. Are they being repeatedly unsuccessfully attempted to get migrated? If so, they are dead, you can delete them.
Nop nothing…
I got one error on one file on another node,
hash mishmatch… where souce hash is empty…
That’s it.
Probably should stop the node, delete the files and usage db
Are those even valid-looking blobs with valid looking filenames? Maybe some unrelated filesystem garbage?
I don’t know.
They end in .sj1 if that helps.
Then they are not migrated yet. They would throw an error during migration, if they are invalid.
Does they have a size greater than 0?
They have a size greater than zero, there are no errors while migrating, not even on continued migration enqueued tries.
This is a sample
I hope it helps
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/w2/hxb7bnupplwrsr5nmg7xc4v62tvka4mebqrm5ewlmi6zgrlhlq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/wc/pdoog37dota7jbfbotmsjlhhq46p2zbusldbjlva2w3myl24ta.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/wc/qasialymw5igctdefse7pabb2k72ztocxhsjrtczok2gub3qsa.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/we/s6jsfkheqvi7tf5swpyxckr57rnj52ncckwmywspig345tmumq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/wh/ezbxxsloqxrsq3d5epyel6a25jqkfjkzr2thzn662fdmpbbfsa.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/wn/q4sbmn57oshkdhfzewjdi4memfib34pup55kyln3l5daemykhq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/wo/si6nflobewkqnnii3cma4xifinlk6wrvr5tzdhfgerhq3na4ka.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/ws/pfnyxsma4zpw6vpx7hspecd24jnrrlv6i2l63rtolmsra6jdwa.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/ww/coxivdtt3p4uqshxr7jf6c7odndymftlyx27ujskxp5wblhuda.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/x3/gepdoai5kpuxmjysbbluqwp5caeqjrpeyc65qdaztht43ig65a.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/x5/7pndj5ikv7vhkkdmygg25k7kreif24sxsqbfzjldudjjdgf2va.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/x6/fonecnnvwj3xvbbtvgvo4ulrvurkbqwofxqbyt7ba6dbwri43q.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/xa/kdbbbpqtnac2j6fgl5pe2qpbcxccpeahfpfi235k6kxcf7dcoa.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/xd/o53dhdinncrejp7obnslwaombvnvxmrjb3wt4p3xbj4nt4d5pq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/xj/li4lmzldusggqazfvhhx3qsg4eud74e5ownt5rhhtp5jc6pkxa.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/xk/ytr2ndtsyfauaw5564rvsmhlfud74dihd5yuz2wcsaewtbrmuq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/xm/ongwmzhkl2artj36yfzbjuf4jywk7d642maernekhp3ahe44bq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/y3/2nwihdxifmgjn5sezdcukwd7r2sz75ywv2hwqhonbeak7tkqxq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/y4/sczjswhxualrsgfhnvhymo2ls4zrofqoe65dug4skuenmydyqa.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/y6/oxz2h37mm6qhhzexdq3lzbe6cvjqnmbze2xx63mxmxalhhzylq.sj1
8.0K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/y7/cy5adpnhvzhvmpbbv2c7qmhc2fliw3tio6h4spu5ny5tuackgq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/yd/b2nt7axhwt5x3u6egrs5ywrqnwlhgmobdkxgpwqbialmm4vwuq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/ye/wl3refukpu4b4q7sgte5oork5soe42cbpewyxhtuivqmpfwq7a.sj1
40K     arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/yf/yc3re7h5st3d7kmxks4fot4kdasgy52zotr545xzjurg2wzedq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/yi/ap7hhpabehnarb4zgqf4fgrhifkh5obsdsijzzi7hsykutq7dq.sj1
4.0K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/yj/hv6x6mxdiyf5wzz5644yhwselfvhlu6qpk2qxkv76n6wb7th6q.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/ys/d4trfzm3z2ximry2x7dfljixs7eydont5mj6ul7rg72oo3z7fq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/yt/2nsh4vabr444zznez3fpbrt4qho7wuvw2gwl5gta6pwk6u5ipq.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/yz/r24fqd7ois4jkuro7xydylzkvoci56yeqlqcezdpkibjps6a6q.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/z5/wqt3wsfnji3qnw7yhveheddmtq7itwd7rmbsx4ugfsceaenvqq.sj1
52K     arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zl/dcd6a4tu37nolkznopy5fznn5digg7vbxuhefshzq4ooldchxa.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zn/3vikxxc2y5kcluaephzhmwyiz4nmi366z7m6smv3sjh5zqieta.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zn/feenmsag7yetcc2iq347slzwmqz4wdyyyb6tdkob55ot4k2hia.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zn/gyuvw7wsxlar42xfaluh7s5ln47womlmnqppjptshfst5xdgia.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zo/mxzdljogztywgiy5ik75hhsxijrn3mwscwwcgffjprz2jvntrq.sj1
4.0K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zq/s6au5xxxcheptpzpj6f5elhyeyiahuet5rqcjg3qg6tnqcldda.sj1
392K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zs/ykzddx43lpgd4rmrppmq2uemrwylphtisq326ptnmeu5odivnq.sj1
348K    arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa/zz/hnch4e2znvxokd6alzfwjxnj5wohswb52ffms6h7czovts3xva.sj1
I have a few nodes with random piecestore that are non zero.
They usually get remove slowly when BF get send out.
These looks like valid pieces, so this piecestore is not migrated yet.
Interesting…
So, you can delete US2 blobs for sure.
Me, I’m just a moron with a Hard Drive. I am not deleting ANYTHING!
Plenty of room to spare for more data.
I’m too scared of breaking something :wink:
US2 has been decommissioned a long time ago, I believe that we didn’t implement deletion at that time yet, so it’s pretty safe to delete data of the decommissioned satellite.
To make it safe, you can use this guide:
I also have blobs from 6r2fgwqz3manwt4aogq343bfkh2n5vvg4ohqqgggrrunaaaaaaaa
also decommissioned.
I am going to delete but there is a lot of data floating around that needs to be deleted, you’ll figure out how to.
I do have this on 3 of my nodes smaller nodes 1 file on each all from US1 server.
For example
INFO    piecemigrate:chore      couldn't migrate        {"process": "storagenode", "error": "hash mismatch: source=,destination=5388095a0cd0b3e9575a3f8f9308385a5ca03854b2627c00a637b5fdad478f93", "sat": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "id": "FWMVK7RZP3IFZHFUVYC4RYMQVMWCIS5IMP4LHPERJX5YR2QGJWDA"}
it’s just one file per node.
is it safe to delete?
I would only remove the file if it is empty.
Else, just leave it alone and BF will eventually take care of it.
Yes, but suggestion from @lyoth is valid too, in that case your node might never fail an audit on missing/corrupted piece, but it could take a lot of time, because it may happen only in these cases:
  • the piece is recovered to another node (your audit score will get a hit);
  • the customer deleted their file.
Watching my logs, it’s still all piecestore.
I think this hashstore is a myth.
Piecestore is still there. Filestore and hashstore are it’s 2 backends.
