Hi!
Thanks for your great work!
How can I make sure to be connected to the right satellites (V3 Network)?
Thanks!
Hi!
Thanks!
Hello @jeremyfritzen
If you have used the signed identity and the beta image and made port forwarding, you already connected to the v3.
If not, I recommend to start from there: https://documentation.storj.io/
All Tardigrade satellites are whitelisted by default in the beta image.
Thank for you quick answer!
Is that normal that I didn’t receive any payment for August?
I started my node on August, 12th.
Thank you!
Absolutely, nobody received. The payout should be sent within the first two weeks of the next month for a previous
