How important is send buffer size?
This is not how it work for TrueNAS Scale. It has k3s (lightweight kubernetes) under the hood. And it’s not easy to pass sysctl parameters to the pod.
In fact it was very easy. You can do it from the gui.
I believe he was responding to me.
Did it work actually? If so, I need to update my old instance.
No more buffer related messages in log. So I guess it works.
Thank you for confirmation!
Meanwhile I applied the bufferbloat limiters to my pfSense box. Although the test without limiters didn’t look bad, internet browsing and gaming feels significantly smoother now.
