All nodes to a single zfs array? How many?
I want to create a 8 drive RAIDz2 with 6 nodes so it’ll be still 1 node per hdd. My case can offer space for around 12 hot swappable hdds, that’s for the very far future to upgrade.
So just one vdev? I would go for two raidz1 vdevs instead, 4 disks in each. This will provide more balanced performance.
I would not plan on adding disks to vdev s, even though it’s supported now. You can always add new vdevs.
Why are you so preoccupied with failures during resolver? With raidz1 resilveing array single disk fault tolerance is maintained throughout the process. If disk dies during resilver no data is lost. There is no reason to have two disk fault tolerances for vast majority of users. And besides, you need to have periodic scrub, (which is much equivalent to resilver) and you won’t have disk failure every other scrub.
This is false. Very. That not at all how this works.
This is just how zfs works in general (see transaction group). Nothing to do with slog.
Slog will make zero difference for storj. It only affects synchronous writes. Are your main workloads predominantly synchronous? Having fast special device is what will be crucial for storj, and all other workloads.
It seems you have a lot of misconceptions about zfs. I’d suggest clearing that out first to avoid spending too much time with ill-fitting configurations.
Thanks, I never thought of that.
Why not? I would like to keep my redundancy, when adding a 3rd RAIDz1, I would have 3 parity drives instead of 2, reducing the possible capacity.
As I read, it tells, it’s for synchronous writes smaller than 1MiB
- takes a long time; adding new vdev is instant.
- has performance impact during additions,
- performs worse than multiple vdevs, (including during rebuilds)
- adding disks to vdev is a rather new feature, and not used by enterprises, therefore has minimal real world test coverage; I would not trust it for a few years, or ever. There is just no need.
But this will keep the ratio of parity to data. If you add another disk to existing vdev you are making the system less reliable. Not that it matters, see above, I’m suggesting two disk redundancy, especially on such small arrays is overkill/waste.
Not the default threshold bit, which is indeed 1MB. The previous sentence i quoted when replying in the comment above.
Slog is not a cache. It is write-only and is never read under normal circumstances. It only speeds up acknowledging of synchronous writes.
Storj produces none (except databases, which you should also make async and/or push to ssd) so it won’t make any difference for Storj. A small caveat is that metadata updates are also done synchronously, and the default 5 second cadence of transaction group writes will contribute to those synchronous writes. The performance improvement due to this would be minimal.
Not a good idea in my opinion. However I am interested to see how it works.
This sounds like a really bad idea.
running 6 nodes on an array is the same as running six nodes on a single disk.
- It’s against storj’s prescriptions (one node per disk).
- if you have 6 nodes kick off housekeeping tasks (filewalkers, garbage cleanup) on 6 nodes simultansouly it’s going to hammer the array
- there is still the max theoretical size that a storj bloom filter can handle for garbage cleanup, which is 24TB I think. So if single node goes over that you’re going to end up with unpaid uncleaned up garbage.
- as mentioned before, a storj node doesn’t need redundancy. storj itself provides the redundancy.
- running multiple nodes under one ip address slows your ingress so they don’t really fill much faster.
Now, if you have the array set up the way you like for your personal storage needs, then I could imagine setting up a single storj node on it and letting it grow. Then if it gets large enough to mostly fill a disk, then migrate it to a new single disk. (bear in mind migration currently takes weeks on large disks), then spin up a new node on the array…
It’s nice, that I’m learning every day something new regarding ZFS. I want to do the Array, because I’m also curious and becoming a fan of ZFS and it’s features. I have 2x4TB Sata SSDs laying around, which I could use as a Special device in Mirror. I think with 4TB and 2% ratio, I’m safe for around 180TB data (not sure I’ll reach that in my lifetime). Do you recommend doing all vdev kinds, like special device, slog and l2arc? My system has around 64GB of ram, and I would like do use some of it for myself, not only ZFS, so I think I need to add some caching. How large do you recommend slog and l2arc size? I also want to host own data on the array, like plex and nextcloud files. I would like just to use “one device” for my files and don’t want to setup several shares on several drives, like SSDs for files who need faster access. I would like to keep it “simple” so that’s why I also want to use ZFS, just “one” share with all the benefits of SSDs and HDDs combined, not splitting it up on several single drives with different characteristics for each use-case.
I myself use ZFS with special metadata duplicated on three SSDs (which are partitioned using LVM, in order to use them for many nodes). No L2ARC aside from in-memory, since no benefit with this setup
What happens if one SSD fails? Do you need to run zpool replace for the metadata device? I would expect No because you only have one (logical) metadata device per zfs pool, right?
Why didn’t you use zpool mirror feature for metadata devices?
He probably is using a 3-way mirror for his metadata device: but he’s mirroring 3 partitions on SSDs, not 3 entire SSDs. That’s very common, because metadata-only (no small files) doesn’t need much space.
So yeah if one of those partitions goes bad… you replace it like any other mirror in ZFS: nothing special.
3-way mirroring is also possible with “normal” zfs features (zpool add X special mirror part1 part2 part3).
I thought his configuration looks more like this:
- each node has it’s own zpool and a special lv* device
- lv0-n (for zfs special device for every zpool) ← vg0 ← pv0-2 (3 ssds mirrored)
so for example 2 nodes:
zpool node0
- special device lv0
- data hdd rust-0
zpool node1
- special device lv1
- data hdd rust-1
So the question is:
- @JWvdV why did you use LVM in combination with zfs?
Please make sure these SSDs support PLP. if not – buy used enterprise SSDs with PLP support from eBay.
This highly depends on the content stored, but 2% is definitely a massive overkill, and will indeed last forever.
For reference, on my pool there is 70TB of data allocated, and 580GB allocated on a special device. This is less than 1%.
details
% zpool list -v
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
boot-pool 103G 6.74G 96.3G - - 5% 6% 1.00x ONLINE -
gptid/0dbcf727-921a-11ec-8600-5404a613ddea 103G 6.74G 96.3G - - 5% 6.54% - ONLINE
pool1 205T 70.4T 135T - - 32% 34% 1.00x ONLINE /mnt
raidz1-0 65.4T 24.4T 41.0T - - 36% 37.4% - ONLINE
gptid/c37ca4dd-8cec-11ee-a737-0025907f338a 16.4T - - - - - - - ONLINE
gptid/0dd0e79b-8f5b-11ee-880d-0025907f338a 16.4T - - - - - - - ONLINE
gptid/fe07bab4-8cec-11ee-a737-0025907f338a 16.4T - - - - - - - ONLINE
gptid/b069f182-9060-11ee-880d-0025907f338a 16.4T - - - - - - - ONLINE
raidz1-2 72.7T 25.2T 47.5T - - 34% 34.6% - ONLINE
gptid/ea5dbbec-2df9-11ef-affd-ac1f6bbbe6a4 18.2T - - - - - - - ONLINE
gptid/6cf2c522-2dfa-11ef-affd-ac1f6bbbe6a4 18.2T - - - - - - - ONLINE
gptid/f8dddfc6-2dfb-11ef-affd-ac1f6bbbe6a4 18.2T - - - - - - - ONLINE
gptid/cf57e9ee-2dfc-11ef-affd-ac1f6bbbe6a4 18.2T - - - - - - - ONLINE
raidz1-4 65.4T 20.2T 45.2T - - 28% 30.8% - ONLINE
gptid/f4b15820-55b0-11ef-9feb-ac1f6bbbe6a4 16.4T - - - - - - - ONLINE
gptid/ce772271-c72b-11ef-af81-c46237009f95 16.4T - - - - - - - ONLINE
gptid/f512d2b5-55b0-11ef-9feb-ac1f6bbbe6a4 16.4T - - - - - - - ONLINE
gptid/f52f0b8a-55b0-11ef-9feb-ac1f6bbbe6a4 16.4T - - - - - - - ONLINE
special - - - - - - - - -
mirror-3 1.82T 583G 1.25T - - 89% 31.3% - ONLINE
gptid/c8bd1b5f-32ca-11ef-b5fc-ac1f6bbbe6a4 1.82T - - - - - - - ONLINE
gptid/d7a0f4ed-32ca-11ef-b5fc-ac1f6bbbe6a4 1.82T - - - - - - - ONLINE
logs - - - - - - - - -
gptid/3843364f-b073-11ec-93ce-5404a613ddea 13.4G 75.5M 12.9G - - 0% 0.56% - ONLINE
It's probably even smaller, depending on how you look at it
Zdb reports total metadata size 70GB – which yields 0.01%
full log
Traversing all blocks ...
bp count: 98408591
ganged count: 61078
bp logical: 17584024401920 avg: 178683
bp physical: 16431646518272 avg: 166973 compression: 1.07
bp allocated: 22409110564864 avg: 227714 compression: 0.78
bp deduped: 0 ref>1: 0 deduplication: 1.00
bp cloned: 0 count: 0
Normal class: 75842432557056 used: 33.90%
Special class 622125375488 used: 31.12%
Embedded log class 0 used: 0.00%
additional, non-pointer bps of type 0: 272398
number of (compressed) bytes: number of bps
17: 34 *
18: 252 *
19: 55 *
20: 223 *
21: 140 *
22: 26310 ****************************************
23: 725 **
24: 166 *
25: 3335 ******
26: 696 **
27: 2041 ****
28: 4461 *******
29: 13965 **********************
30: 1215 **
31: 1002 **
32: 2049 ****
33: 5524 *********
34: 1391 ***
35: 1088 **
36: 1333 ***
37: 1112 **
38: 645 *
39: 897 **
40: 1075 **
41: 1111 **
42: 1012 **
43: 15272 ************************
44: 1731 ***
45: 768 **
46: 676 **
47: 910 **
48: 821 **
49: 1306 **
50: 1418 ***
51: 1859 ***
52: 1416 ***
53: 2332 ****
54: 4086 *******
55: 4027 *******
56: 6513 **********
57: 14490 ***********************
58: 6180 **********
59: 6429 **********
60: 4412 *******
61: 4979 ********
62: 3437 ******
63: 3277 *****
64: 2440 ****
65: 1742 ***
66: 2306 ****
67: 2192 ****
68: 3336 ******
69: 2721 *****
70: 2154 ****
71: 2029 ****
72: 1894 ***
73: 2091 ****
74: 2178 ****
75: 2199 ****
76: 2419 ****
77: 3519 ******
78: 2168 ****
79: 2059 ****
80: 2264 ****
81: 1891 ***
82: 2021 ****
83: 2276 ****
84: 2226 ****
85: 2191 ****
86: 2146 ****
87: 9919 ****************
88: 1803 ***
89: 1794 ***
90: 1590 ***
91: 1941 ***
92: 1678 ***
93: 1651 ***
94: 1818 ***
95: 1958 ***
96: 1745 ***
97: 1724 ***
98: 1720 ***
99: 4044 *******
100: 3315 ******
101: 1617 ***
102: 1631 ***
103: 1329 ***
104: 1303 **
105: 1381 ***
106: 1528 ***
107: 1532 ***
108: 1486 ***
109: 7598 ************
110: 1494 ***
111: 1485 ***
112: 2656 *****
Dittoed blocks on same vdev: 5818943
Blocks LSIZE PSIZE ASIZE avg comp %Total Type
- - - - - - - unallocated
2 32768 8192 24576 12288 4.00 0.00 object directory
4 131072 23040 135168 33792 5.69 0.00 L1 object array
221 113152 113152 4300800 19460 1.00 0.00 L0 object array
225 244224 136192 4435968 19715 1.79 0.00 object array
2 32768 8192 24576 12288 4.00 0.00 packed nvlist
- - - - - - - packed nvlist size
1 32768 4096 12288 12288 8.00 0.00 L2 bpobj
220 7208960 1007616 3035136 13796 7.15 0.00 L1 bpobj
8673 1136787456 70682624 212410368 24490 16.08 0.00 L0 bpobj
8894 1144029184 71694336 215457792 24225 15.96 0.00 bpobj
- - - - - - - bpobj header
- - - - - - - SPA space map header
14054 230260736 56133632 172707840 12288 4.10 0.00 L1 SPA space map
81629 10699276288 7266537472 22575157248 276558 1.47 0.10 L0 SPA space map
number of ganged blocks: 6
95683 10929537024 7322671104 22747865088 237741 1.49 0.10 SPA space map
18 745472 745472 745472 41415 1.00 0.00 ZIL intent log
350 45875200 1433600 2908160 8309 32.00 0.00 L5 DMU dnode
349 45744128 1429504 2899968 8309 32.00 0.00 L4 DMU dnode
349 45744128 1429504 2899968 8309 32.00 0.00 L3 DMU dnode
352 46137344 1515520 3076096 8738 30.44 0.00 L2 DMU dnode
2784 364904448 112989184 226553856 81377 3.23 0.00 L1 DMU dnode
1661428 27220836352 6732938752 13781274624 8294 4.04 0.06 L0 DMU dnode
1665612 27769241600 6851736064 14019612672 8417 4.05 0.06 DMU dnode
357 1462272 1462272 2969600 8318 1.00 0.00 DMU objset
- - - - - - - DSL directory
59 31744 3072 49152 833 10.33 0.00 DSL directory child map
57 87040 57856 245760 4311 1.50 0.00 DSL dataset snap map
76 578560 140800 479232 6305 4.11 0.00 DSL props
- - - - - - - DSL dataset
- - - - - - - ZFS znode
- - - - - - - ZFS V0 ACL
77 2523136 315392 638976 8298 8.00 0.00 L3 ZFS plain file
22729 744783872 93669888 191963136 8445 7.95 0.00 L2 ZFS plain file
3562294 116729249792 16231137280 33005772800 9265 7.19 0.15 L1 ZFS plain file
92459063 17419918568960 16399359938048 22334742589440 241563 1.06 99.67 L0 ZFS plain file
number of ganged blocks: 61072
96044163 17537395125760 16415685060608 22367940964352 232892 1.07 99.82 ZFS plain file
1028 33685504 3791360 8421376 8192 8.88 0.00 L2 ZFS directory
30786 1008795648 135128576 285409280 9270 7.47 0.00 L1 ZFS directory
507462 5671192576 1539297792 3438469120 6775 3.68 0.02 L0 ZFS directory
539276 6713673728 1678217728 3732299776 6920 4.00 0.02 ZFS directory
44 45056 45056 507904 11543 1.00 0.00 ZFS master node
19 622592 77824 155648 8192 8.00 0.00 L1 ZFS delete queue
577 5487104 1310720 2621440 4543 4.19 0.00 L0 ZFS delete queue
596 6109696 1388544 2777088 4659 4.40 0.00 ZFS delete queue
- - - - - - - zvol object
- - - - - - - zvol prop
- - - - - - - other uint8[]
- - - - - - - other uint64[]
- - - - - - - other ZAP
- - - - - - - persistent error log
1 32768 16384 49152 49152 2.00 0.00 L1 SPA history
214 28049408 2926592 10211328 47716 9.58 0.00 L0 SPA history
215 28082176 2942976 10260480 47723 9.54 0.00 SPA history
- - - - - - - SPA history offsets
- - - - - - - Pool properties
- - - - - - - DSL permissions
- - - - - - - ZFS ACL
- - - - - - - ZFS SYSACL
- - - - - - - FUID table
- - - - - - - FUID table size
36 22528 4096 12288 341 5.50 0.00 DSL dataset next clones
- - - - - - - scan work queue
870 759296 422400 1769472 2033 1.80 0.00 ZFS user/group/project used
- - - - - - - ZFS user/group/project quota
- - - - - - - snapshot refcount tags
- - - - - - - DDT ZAP algorithm
- - - - - - - DDT statistics
51144 27921920 27916800 418897920 8190 1.00 0.00 System attributes
- - - - - - - SA master node
44 67584 67584 516096 11729 1.00 0.00 SA attr registration
88 1441792 360448 1015808 11543 4.00 0.00 SA attr layouts
- - - - - - - scan translations
- - - - - - - deduplicated block
446 818176 722944 4534272 10166 1.13 0.00 DSL deadlist map
- - - - - - - DSL deadlist map hdr
24 16896 4096 12288 512 4.12 0.00 DSL dir clones
4 524288 13312 61440 15360 39.38 0.00 bpobj subobj
- - - - - - - deferred free
- - - - - - - dedup ditto
40 1310720 163840 491520 12288 8.00 0.00 L1 other
558 2428416 524288 4534272 8125 4.63 0.00 L0 other
598 3739136 688128 5025792 8404 5.43 0.00 other
350 45875200 1433600 2908160 8309 32.00 0.00 L5 Total
349 45744128 1429504 2899968 8309 32.00 0.00 L4 Total
426 48267264 1744896 3538944 8307 27.66 0.00 L3 Total
24110 824639488 98980864 203472896 8439 8.33 0.00 L2 Total
3610202 118342516736 16536677376 33694310400 9333 7.16 0.15 L1 Total
94773154 17464717359104 16415006252032 22375203434496 236092 1.06 99.85 L0 Total
number of ganged blocks: 61078
98408591 17584024401920 16431646518272 22409110564864 227714 1.07 100.00 Total
5948872 164102062592 32285892096 74362949632 12500 5.08 0.33 Metadata Total
Block Size Histogram
block psize lsize asize
size Count Size Cum. Count Size Cum. Count Size Cum.
512 202282 103568384 103568384 150262 76934144 76934144 0 0 0
1024 2326134 2957831168 3061399552 2287732 2930058240 3006992384 0 0 0
2048 1557704 4288518144 7349917696 1532560 4239606784 7246599168 0 0 0
4096 7381636 33058527744 40408445440 1813787 10383113216 17629712384 93657 383619072 383619072
8192 3155435 36815309824 77223755264 2581627 30790138368 48419850752 9904189 81283747840 81667366912
16384 2886615 65362488832 142586244096 4278774 84719106048 133138956800 5020826 96235188224 177902555136
32768 3938321 174830935040 317417179136 6209236 227794521088 360933477888 4548540 200904597504 378807152640
65536 4007373 374690483200 692107662336 1103730 96534283264 457467761152 3560800 323255410688 702062563328
131072 63907816 8512431848448 9204539510784 68389320 9044851895808 9502319656960 65474659 11803360190464 12505422753792
262144 1088600 368261090304 9572800601088 934150 309772929024 9812092585984 1694704 637099204608 13142521958400
524288 2371165 1287644188672 10860444789760 2939128 1547666604032 11359759190016 2452196 1739845967872 14882367926272
1048576 5313112 5571201728512 16431646518272 5915887 6203257126912 17563016316928 5386622 7526742638592 22409110564864
2097152 0 0 16431646518272 0 0 17563016316928 0 0 22409110564864
4194304 0 0 16431646518272 0 0 17563016316928 0 0 22409110564864
8388608 0 0 16431646518272 0 0 17563016316928 0 0 22409110564864
16777216 0 0 16431646518272 0 0 17563016316928 0 0 22409110564864
capacity operations bandwidth ---- errors ----
description used avail read write read write read write cksum
pool1 69.5T 136T 5.68K 0 25.0M 0 0 0 0
raidz1 24.2T 41.2T 29 0 122K 0 0 0 0
/dev/gptid/c37ca4dd-8cec-11ee-a737-0025907f338a 7 0 30.5K 0 0 0 0
/dev/gptid/0dd0e79b-8f5b-11ee-880d-0025907f338a 7 0 31.0K 0 0 0 0
/dev/gptid/fe07bab4-8cec-11ee-a737-0025907f338a 7 0 30.7K 0 0 0 0
/dev/gptid/b069f182-9060-11ee-880d-0025907f338a 7 0 29.9K 0 0 0 0
/dev/gptid/3843364f-b073-11ec-93ce-5404a613ddea (log) 808K 13.0G 0 0 528 0 0 0 0
raidz1 24.9T 47.8T 3 0 15.2K 0 0 0 0
/dev/gptid/ea5dbbec-2df9-11ef-affd-ac1f6bbbe6a4 0 0 3.81K 0 0 0 0
/dev/gptid/6cf2c522-2dfa-11ef-affd-ac1f6bbbe6a4 0 0 3.67K 0 0 0 0
/dev/gptid/f8dddfc6-2dfb-11ef-affd-ac1f6bbbe6a4 0 0 3.80K 0 0 0 0
/dev/gptid/cf57e9ee-2dfc-11ef-affd-ac1f6bbbe6a4 0 0 3.89K 0 0 0 0
mirror (special) 579G 1.25T 5.65K 0 24.9M 0 0 0 0
/dev/gptid/c8bd1b5f-32ca-11ef-b5fc-ac1f6bbbe6a4 2.82K 0 12.4M 0 0 0 60
/dev/gptid/d7a0f4ed-32ca-11ef-b5fc-ac1f6bbbe6a4 2.83K 0 12.5M 0 0 0 60
raidz1 19.9T 45.5T 0 0 2.26K 0 0 0 0
/dev/gptid/f4b15820-55b0-11ef-9feb-ac1f6bbbe6a4 0 0 582 0 0 0 0
/dev/gptid/ce772271-c72b-11ef-af81-c46237009f95 0 0 573 0 0 0 0
/dev/gptid/f512d2b5-55b0-11ef-9feb-ac1f6bbbe6a4 0 0 591 0 0 0 0
/dev/gptid/f52f0b8a-55b0-11ef-9feb-ac1f6bbbe6a4 0 0 564 0 0 0 0
Depends on your workload. I definitely recommend special device. This makes night and day in performance. Furetheremore, since you have massive amount of space on special device, you can configure datasets to sends files smaller than specified size to special device as well. You can build a histogram of files you have now, and see what threshold size will end up with the best utilization of your SSDs.
Slog will help offload IO from main army for the intent log. 100-200MB is plenty for most users. Buy smallest optane you can find - which is 16GB for $10 last I checked.
you probably don’t need L2ARC. But if you have one laying around – might as well stick it there. But not necessary.
It’s the other way around. ZFS will use whatever is leftover for ARC. So, make sure there is some leftover. 32GB shall be fine.
Slog is not a cache. l2ARC is a cache, but it’s filling very slowly on purpose. See above for recommendation.
Create one pool. On that one pool you can have multiple datasets. Each dataset can have its own parameters – like sync on/off, atime on/off, record size, compression (don’t disable compression), and small block size, to fit the usecase. To force files to SSD all you need to do is set small block size greater or equal to record size.
For example, you would disable sync and atime updates for dataset that holds storj data, but keep it on for, say, dataset that keep Time Machine bundles, or users homes.
To start with, keep everything at defaults. Defautls on ZFS are the best settings for vast majority of scenarios. Only change settings after you found bottleneck and fully understand the effects (both beneficial and detrimental) of the change. Most new users rush to mess with compression and record size - try to refrain from doing so, until you stumble on a reason to, and then measure effect before and after the change.
ZFS is very robust and low maintenance, and works well out of the box.
So the question is:
Because I created logical devices for vdevs on three SSDs with LVM, in a ratio of 5GB/TB for every hard drive. So I use three SSDs for about 12 hard drives with variable sizes. And in that way, every hard drive has three mirrored vdevs.
I would add that it doesn’t rebalance the data, so it will not improve the speed.
It should be pointed out this can actually be bad on a low RAM system because L2ARC also consumes RAM to track the objects in it.
It does consume some ram, but that small amount of ram facilitates caching of larger amount of data; in predominately repetitive read scenarios it’s still a net win.
I got my M10 SSDs from Aliexpress (2,50€ each) now, I created a test pool and wanted to add the ssd as SLOG, unfortunately, the SSD has 512e sectors, my pool 4Kn, so SLOG isn’t possible with this SSD. I tried the Intel MAS tool and the nvme tool on linux, but no chance converting this SSD to 4Kn. What can I do? How did you managed to get it work?
Oh my…
First of all, why are you buying SSDs on AliExpress?
Second, you don’t need slog. Disable sync on storj dataset instead.
Third – it’s not up to ssd what sector size you use. Use ashift parameter when adding it to the array to specify any sector size you want.
Also… wasn’t the node switched to request async writes by default? I feel like that was part of an upgrade within the last year… but my search skills struggle to find it.
(When @gingerbread233 mentioned M10’s: I’m guessing he found a sale blowing out those baby Optane drives?)
Not all optane drives from AliExpress would be optane drives except the label.. And not always has the promoted physical capacity.
