How To Forget Untrusted Satellites
ok thx it works . sry
I have tried both methods however I am having more than 1 node where none of them is working.
2024-01-18T04:04:44Z    INFO    Configuration loaded    {"process": "storagenode", "Location": "/app/config/config.yaml"}
2024-01-18T04:04:45Z    INFO    Anonymized tracing enabled      {"process": "storagenode"}
2024-01-18T04:04:45Z    INFO    Identity loaded.        {"process": "storagenode", "Node ID": "Redacted"}
2024-01-18T04:04:45Z    WARN    Satellite not found in satelliteDB cache. Forcing removal of satellite data.    {"process": "storagenode", "satelliteID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
2024-01-18T04:04:45Z    INFO    Removing satellite from trust cache.    {"process": "storagenode", "satelliteID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
2024-01-18T04:04:45Z    INFO    Cleaning up satellite data.     {"process": "storagenode", "satelliteID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
It seems that it doesn’t even make it to the second satellite. On these nodes the number of blob folders remain at 6 and the remain filled with data.
So what should I do?
Please show your command
I have tried these 2:
docker exec -it storagenode ./storagenode forget-satellite --all-untrusted --config-dir config --identity-dir identity
docker exec -i storagenode ./storagenode forget-satellite --force 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB  12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo --config-dir config --identity-dir identity
this will work only if you modified your config.yaml:
but this one:
should work, unless you re-created your databases recently after these satellites were shutdown.
In the last case I believe you can only remove their folders from the blobs folder manually, see Satellite info (Address, ID, Blobs folder, Hex)
I am not sure but it could be. At least it would explain why the command is working on some node and not on others. Then I’ll remove those blob folders by handy. Anything else I need to do?
You may still add them to the untrusted list. I do not think that it could make any difference though.
I GE Saltlake and I want it gone from my dashboard. I manualy deleted the blobs and trash folder for it, but I can’t remember where to put it in the config. I know you told me a few months back, but I forgot to take note.
It’s a parameter in the config… an untrusted list I think?
And what is the correct syntax/format?
Yes
storage2.trust.exclusions: "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB@europe-north-1.tardigrade.io:7777,12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo@us2.storj.io:7777"
I just saw on a node that it has 4 folders in the blobs folder but still 6 in the trash.
The trash folders from the 2 retired satellites appear empty.
But they are still present. Now the question is, do I have to check on all nodes if they are really empty or can I be sure that all trash data of the retired satellites has been deleted?
Why did the trash folder did not get deleted?
you may do a pull request with a proposed change
I am still not a coder and I have no idea what a pull request is.
Hello, if I was to run these command How To Forget Untrusted Satellites
Could I run it while another docker container is running and use the same volume (storagenode) ? I suppose yes?
P/s: yes it is How To Forget Untrusted Satellites - #2 by zip (BTW, this info should be inside the main post, not on the answer)
I came across this in a reference to this thread elsewhere. I feel like this should be more widely publicized and/or something automated within the node. This cleaned up a lot of useless data stuck on my storage device and seems to have cleared up something that was causing my node to think it was “full” when it wasn’t.
This forum post is a documentation for this process.
How would you expect it to be exposed more?
I only found this because I saw your post here: Earnings calculator (Update 2024-04-14: v13.4.0 - Additional info on uncollected garbage and unpaid data - Detailed earnings info and health status of your node, including vetting progress) - #573 by Alexey
Which lead me to check my blobs folder and discover I had extra folders and went through the process here. I’m not an “expert” here, but I’ve been a SNO for a while now and I check on the community post daily, and I have not come across this till now.
Maybe I’m an outlier and maybe I missed some sort of announcement in an email, but it seems like this would be a good topic to highlight in a routine email to SNOs.
20k emails? And do you expect us not banned?
Then you are a believer. Sorry, it’s not possible with current limitations.
The best way for actions is to monitor the forum. I cannot suggest anything else, sorry!
I’ve research into this topic and see this number is…not high at all? The trustability in email business is wierd though, the more you send the more trust you have. Just a few month ago, AWS free tier email is AWS to remove 62,000-message Simple Email Service ‘always free’ tier | Hacker News, and I remember correctly, some legend said they send hundred of thousands per day.
Also, I’ve share the view the remove of satellite should happen automatically, reduce the cognitive burden of SNO and manual action.
