Hello - I triggered graceful exit at the end of last month.
How can I check to know if it is still in progress or failed?
I ran the docker exec -it storagenode /app/bin/storagenode exit-status --config-dir /app/config --identity-dir /app/identity command several time over the month but it still says 0.00% and N
So does it not increase and just goes from 0 > 100?
Should I expect the data on disk to drop off?
Is there anything I can check to see how much longer?
