How to reset Webbrowser encryption phrase?
How to reset Webbrowser encryption phrase ? I played around with server side encryption. However i wrote not doen the seed. How can I reset the SEED phrase.
I know data is lost. Due to it was only test data to test this feature.
You do not need to reset it, you can write your own. It will warn that it’s different from used before, but you can acknowledge that and continue.
The only downside, that you would not see files uploaded with a previous phrase.
To delete now lost files you need to use the uplink CLI with --encrypted flag
