Goodmorning,
I have an active nod
e for months,
everything worked perfectly! Suddenly after upgrading to version 0.20.1, I have lots of failed uploads, but I’ve never lost DATA! I have only one HDD connected to a PC dedicated to STORJ!
How is it possible?
DASHBOARD
Storage Node Dashboard ( Node Version: v0.20.1 )
ID 1xfv1DbmFi4dKkTALh4ArXEXcvjy9Lia3rgw2Y8g9pDJvmrYNU
Last Contact 0s ago
Uptime 79h1m1s
Available Used Egress Ingress
Bandwidth 4.8 TB 185.7 GB 15.9 GB 169.9 GB (since Sep 1)
Disk 439.5 GB 460.5 GB
Bootstrap bootstrap.storj.io:8888
Internal 127.0.0.1:7778
External my:28967
Neighborhood Size 364
LOG FILE
2019-09-16T13:58:35.895Z ERROR server gRPC stream error response {“error”: “piecestore protocol: rpc error: code = Canceled desc = context canceled”, “errorVerbose”: “piecestore protocol: rpc error: code = Canceled desc = context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:242\n\tstorj.io/storj/pkg/pb._Piecestore_Upload_Handler:851\n\tstorj.io/storj/pkg/server.(*Server).logOnErrorStreamInterceptor:23\n\tgoogle.golang.org/grpc.(*Server).processStreamingRPC:1127\n\tgoogle.golang.org/grpc.(*Server).handleStream:1178\n\tgoogle.golang.org/grpc.(*Server).serveStreams.func1.1:696”}
2019-09-16T13:58:36.731Z INFO piecestore upload failed {“Piece ID”: “4M65ISV4O4UYFHZAQYTAGESBQP6EOFF2WBICQHHW74FEQLD5742A”, “SatelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “error”: “piecestore protocol: rpc error: code = Canceled desc = context canceled”, “errorVerbose”: “piecestore protocol: rpc error: code = Canceled desc = context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:242\n\tstorj.io/storj/pkg/pb._Piecestore_Upload_Handler:851\n\tstorj.io/storj/pkg/server.(*Server).logOnErrorStreamInterceptor:23\n\tgoogle.golang.org/grpc.(*Server).processStreamingRPC:1127\n\tgoogle.golang.org/grpc.(*Server).handleStream:1178\n\tgoogle.golang.org/grpc.(*Server).serveStreams.func1.1:696”}
2019-09-16T13:58:36.731Z ERROR server gRPC stream error response {“error”: “piecestore protocol: rpc error: code = Canceled desc = context canceled”, “errorVerbose”: “piecestore protocol: rpc error: code = Canceled desc = context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:242\n\tstorj.io/storj/pkg/pb._Piecestore_Upload_Handler:851\n\tstorj.io/storj/pkg/server.(*Server).logOnErrorStreamInterceptor:23\n\tgoogle.golang.org/grpc.(*Server).processStreamingRPC:1127\n\tgoogle.golang.org/grpc.(*Server).handleStream:1178\n\tgoogle.golang.org/grpc.(*Server).serveStreams.func1.1:696”}
2019-09-16T13:58:38.073Z INFO piecestore upload started {“Piece ID”: “F2TLN7NK65MSWSXPQBN24RBVQ4FLZP4SGFCIZUNZQSESGZQB3WPA”, “SatelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”}
2019-09-16T13:58:38.699Z INFO piecestore upload failed {“Piece ID”: “3HW75JKTM6OO3XDZ476WRUMLQQDQ2J325PKH647BXP4WORD5WQSA”, “SatelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “error”: “piecestore protocol: rpc error: code = Canceled desc = context canceled”, “errorVerbose”: “piecestore protocol: rpc error: code = Canceled desc = context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:242\n\tstorj.io/storj/pkg/pb._Piecestore_Upload_Handler:851\n\tstorj.io/storj/pkg/server.(*Server).logOnErrorStreamInterceptor:23\n\tgoogle.golang.org/grpc.(*Server).processStreamingRPC:1127\n\tgoogle.golang.org/grpc.(*Server).handleStream:1178\n\tgoogle.golang.org/grpc.(*Server).serveStreams.func1.1:696”}
2019-09-16T13:58:38.700Z ERROR server gRPC stream error response {“error”: “piecestore protocol: rpc error: code = Canceled desc = context canceled”, “errorVerbose”: “piecestore protocol: rpc error: code = Canceled desc = context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:242\n\tstorj.io/storj/pkg/pb._Piecestore_Upload_Handler:851\n\tstorj.io/storj/pkg/server.(*Server).logOnErrorStreamInterceptor:23\n\tgoogle.golang.org/grpc.(*Server).processStreamingRPC:1127\n\tgoogle.golang.org/grpc.(*Server).handleStream:1178\n\tgoogle.golang.org/grpc.(*Server).serveStreams.func1.1:696”}
Successful: 988
Recoverable failed: 290
Unrecoverable failed: 0
Success Min: 77.3082942097027%
Success Max: 100%
Successful: 12850
Failed: 6810
Success Rate: 65.3611393692777
Successful: 23254
Rejected: 3780
Failed: 50728
Acceptance Rate: 86.017607457276
Success Rate: 31.4319699386337
Successful: 0
Failed: 0
Success Rate: 0
Successful: 0
Failed: 0
Success Rate: 0
I proceeded to make constant backups of the data on another disk, stopping the node, starting the backup and then restarting the node.
Not that the data shown by the dashboard is also incorrect.
170GB are downloaded for download in September, but actually less have been downloaded, around 10Gb of new data.
I don’t understand how it can be said sincerely.
Best Regards,
Tony
