What if I see only: ERR_CONNECTION_TIMED_OUT
I may guess that you see this error when trying to open a dashboard in your browser.
If so, please provide 20 last lines from your logs: How do I check my logs? - Storj Node Operator Docs between two new lines with three backticks like this:
log lines
I found best solution. Program name is Radmin 3. It is free to use and I get full control from local computer to my node PC.
Ah I see. You trying to access your storagenode dashboard from the other device. In that case you may use this guide: How to remote access the web dashboard - Storj Node Operator Docs
