Identity generation for second node
Quick question.
The instructions for generating an identity state the command “identity generate storagenode”
If I’m creating a second identity for a second (or third or nth) node on the same machine should I change the command to “identity generate newnodename” or do I keep the command the same?
Thanks! :smiley:
yes, command is the same, just run it, copy the identity somewhere safe, and run it again, and again
Its creating identity :slight_smile:
identity create storagenode
Yes, you can try this
identity create storagenode2
This will be stored at appdata\storj\identity\storagenode2 (in Windows)
You can use this exact path for your second node.
That shouldn’t be the real solution. Follow what @nerdatwork suggested.
