I’m running 4 Nodes in a small Debian 11 VM (12 GB RAM) on my NAS. Each of them has a separate EXT4 drive passed through directly into the VM. Since the last update to 1.39.5 I am seeing my Debian VM freezing quite often and when I check the logs, it’s always some out of memory issues.
I am wondering now if I should limit the amount of memory that each Storj Node can use like described for raspberry pi 3 here:
–memory=800m
Now my question is what impact this might have on my nodes. Will they only use up to 800mb then and work fine or will they crash if they need more than 800mb?
The OOM killer will come when the node would try to get more. This option is used to prevent freeze on raspberry Pi3 because of low amount of RAM.
However, if your nodes started to use more RAM, I would recommend to check your drives. The storagenode uses more RAM when the disk is not keep up with changes.
I’ve literally did that a week ago after seeing that one of my 16 nodes disabled my home server for several hours by heavily swapping… for the third time in a month. This didn’t happen before, so I blame that on either a software update or maybe an unusual distribution of traffic, because none of the other nodes, even hosted on the same file system as the swapping one, did so.
The faulty node is the only one with still free space, so it’s the only one that accepts ingress; it’s my newest node, so it has quite fresh data, and not much of it either, ~400 GB.
In my case I settled on 500m though. So far it works.
I wish there was a similar setting that instead of the OOM killer, it would gracefully restart the node. But I was short on time and didn’t find a better solution quickly enough.
Yeah, I actually prefer to kill a node than the kernel ^^ This box has 2 GB of RAM, running all 16 nodes and some other minor services, which I value more than any single node. And, until recently, I didn’t see much swap usage.
If it turns out that in few releases nodes will actually require more RAM, I’ll probably give up on Storj.
A little bit overkill. The only helps, that you have only one of them with free space. On 2GB I would not run more than 4-6 nodes, especially if the system is used for something else or have a GUI.
However, it depends.
I have three nodes on one system, which is used also as hypervisor. Two of them have a free space, but I did not saw a high memory usage
CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
977a4d89e098 storagenode2 3.68% 52.72MiB / 24.81GiB 0.21% 65.9GB / 32GB 0B / 0B 29
and
Name Mem (MiB)
storagenode 57
The only Pi node have more used RAM for some reason
63537427dc54 storagenode 0.05% 149.8MiB / 800MiB 18.73% 0B / 0B 0B / 0B 20
I am observing the same. My server was always running the nodes very well, but now since 1-2 weeks I am running frequently into issues that the nodes need too much resources…
Staged startup/restarts and I manually trigger updates, I’m not using watchtower. Only one node at a time scans the file system, and none of the nodes are bigger than 1TB.
Small update from my side. I see that my node starts consuming large amount of memory roughly every four days:
2021-10-01T19:31:18.460Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-10-05T15:47:26.232Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
And restarted it manually few minutes ago (so around 2021-10-09T08:00:00Z) again before it hit the threshold. Yet ~10 hours ago there was no indication of elevated memory use.
