mario@mario-System-Product-Name:~$ sudo docker ps -a
[sudo] password for mario:
056e24665bd8 storjlabs/storagenode:latest “/entrypoint” 3 minutes ago Restarting (1) 55 seconds ago storagenode
ea94ca17f827 hello-world “/hello” About an hour ago Exited (0) About an hour ago competent_almeida
515600df2ad3 hello-world “/hello” About an hour ago Exited (0) About an hour ago jovial_dijkstra
15a27a41a453 hello-world “/hello” 3 hours ago Exited (0) 3 hours ago nostalgic_brahmagupta
ec4cdc6e47f1 hello-world “/hello” 3 hours ago Exited (0) 3 hours ago pensive_goodall
something is wrong because i cant bring up the web dashboard on the node itself
mario@mario-System-Product-Name:~$ docker ps -a
056e24665bd8 storjlabs/storagenode:latest “/entrypoint” 11 minutes ago Restarting (1) 30 seconds ago storagenode
and thats all it says
mario@mario-System-Product-Name:~$ docker logs --tail 20 storagenode
–log.caller if true, log function filename and line number
–log.development if true, set logging to development mode
–log.encoding string configures log encoding. can either be ‘console’, ‘json’, or ‘pretty’.
–log.level Level the minimum log level to log (default info)
–log.output string can be stdout, stderr, or a filename (default “stderr”)
–log.stack if true, log stack traces
–metrics.addr string address(es) to send telemetry to (comma-separated) (default “collectora.storj.io:9000”)
–metrics.app string application name for telemetry identification (default “storagenode”)
–metrics.app-suffix string application suffix (default “-release”)
–metrics.instance-prefix string instance id prefix
–metrics.interval duration how frequently to send up telemetry (default 1m0s)
–tracing.agent-addr string address for jaeger agent (default “agent.tracing.datasci.storj.io:5775”)
–tracing.app string application name for tracing identification (default “storagenode”)
–tracing.app-suffix string application suffix (default “-release”)
–tracing.buffer-size int buffer size for collector batch packet size
–tracing.enabled whether tracing collector is enabled
–tracing.interval duration how frequently to flush traces to tracing agent (default 0s)
–tracing.queue-size int buffer size for collector queue size
–tracing.sample float how frequent to sample traces
This is example how to place code here and keep all symbols from converting by the forum engine.
Any text placed between two new lines with three backticks will not be touched.
