Hi all,
I run my node under Linux. I assigned 950GB for the storage.
But now the Node shows that it is full but only used 834GB.
Is this normale? In the trash is only 9GB and under garbage is nothing (4k).
It put some buffer space usualy
Could you please show your dashboard and result of the command:
df -h
Filesystem Size Used Avail Use% Mounted on
udev 3.8G 0 3.8G 0% /dev
tmpfs 778M 3.0M 775M 1% /run
/dev/sdb2 1.4T 846G 459G 65% /
tmpfs 3.8G 0 3.8G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 3.8G 0 3.8G 0% /sys/fs/cgroup
/dev/sdb1 511M 7.6M 504M 2% /boot/efi
/dev/loop5 55M 55M 0 100% /snap/lxd/12317
tmpfs 778M 0 778M 0% /run/user/1000
/dev/loop3 55M 55M 0 100% /snap/lxd/12631
/dev/loop1 90M 90M 0 100% /snap/core/8213
/dev/loop2 90M 90M 0 100% /snap/core/8268
overlay 1.4T 846G 459G 65% /var/lib/docker/overlay2/ad80e708c9e5ebb5f45784ca80c4a8efd9bc6bc6838566c20b7c0c48aefc521f/merged
Please, show the CLI dashboard or result of this command:
docker inspect storagenode -f "{{ .Config.Env }}" | grep -Po "STORAGE=.*? "
This is the output from the command.
STORAGE=950GB
CLI Dashboard
Last Contact ONLINE
Uptime 397h45m5sAvailable Used Egress Ingress Bandwidth 40.0 TB 6.0 GB 5.9 GB 89.0 MB (since Jan 1) Disk -9.7 MB 0.9 TB
Could part of the problem be because your system displays sizes in GiB? 834GiB roughly equals 896GB (which still doesn’t match your assigned 950GB though).
Note: I believe you can use the international unit by using “-H” instead of -h when using df, so all your values (system & storage node) are displayed using the same scale.
Hi, thats funny…now the data is this:
> root@freenas:~# df -H
> udev 4.1G 0 4.1G 0% /dev
> tmpfs 815M 3.1M 812M 1% /run
> /dev/sdb2 1.5T 908G 493G 65% /
> tmpfs 4.1G 0 4.1G 0% /dev/shm
> tmpfs 5.3M 0 5.3M 0% /run/lock
> tmpfs 4.1G 0 4.1G 0% /sys/fs/cgroup
> /dev/sdb1 536M 8.0M 528M 2% /boot/efi
> /dev/loop5 58M 58M 0 100% /snap/lxd/12317
> tmpfs 815M 0 815M 0% /run/user/1000
> /dev/loop3 58M 58M 0 100% /snap/lxd/12631
> /dev/loop1 94M 94M 0 100% /snap/core/8213
> /dev/loop2 94M 94M 0 100% /snap/core/8268
> overlay 1.5T 908G 493G 65% /var/lib/docker/overlay2/ad80e708c9e5ebb5f45784ca80c4a8efd9bc6bc6838566c20b7c0c48a efc521f/merged
Have you problems with a database in the past?
No, no problems since start. The only thing i change was that i assigned more storage in the docker command after an software update.
Try to restart the node and look what happened
ok, i restarted it (i had to do an update to 0.28.4 now) it is running and connected but it shows the same data as before. now i am in the negative.
now the dashboard shows 10GB free space and the networktraffic start up/downloading again…i wait and see what happens
