No im not doing it on a live node just a testnode on the testnet I seem to be a bit rusty and I need to relearn everything again so Im just messing around to see if I can screw it up. I honestly dont want to tell people to do the wrong things.
I tested it on the testnet and I was able to remove all the database files Plus the storage-ver and re run setup and get the node back up and running again. So if you do loose the storage file + the database files you can get your node back up and running that way. Probably not the best way but it still works.
Of course you can make it running again, because the setup step will re-create the storage-dir-verification, which will allow you to run a storagenode, the storagenode re-creates missed database.
But! If you do not remove storage-dir-verification, you doesn’t need to run setup. The only running storagenode is enough to re-create databases, if there is no one *.db file.
The setup step creates the needed folder structure, config.yaml and storage/storage-dir-verification file.
You can also use the storagenode setup command (see storagenode setup --help).
Well, actually I did as @deathlessdd said, because I had no storage-dir-verification file. So I’ve run setup with original identity, run “new” node until databases creation and copied missing files to my old location. That worked fine, because as @Stob told, I was missing this file also…
How did that happen? No Idea. I decided to add --remove-source-files to rsync to check that actually all files are now on my new HDD and old one is empty. Output was fine, so I terminated sync and restarted it with same arguments. And well, all files in first subfolders in /app/config where deleted alongside with databases …
