LVM + EXT4 metadata pool recommended size
According to the sqlite reference, you can actually even add ordering to an index: CREATE INDEX
So, in each case the ordering can be matched with your ordering clause.
Those inserts aren’t that much a problem, since done over a considerable amount of time. Those deletes might also be batched, also reducing the impact.
Indeed, so we agree on the fact that read cache is a read cache and probably didn’t reduce deletion times perse. Although especially the filewalking time might be reduced and finding meta data / inodes from expired pieces might be much quicker.
Nice overview, in each case it’s such enough to say there’s not a real problem anymore. These are also all lazy filewalkers?
Might be. I just prefer not to use statements like “file deletions aren’t optimized” when the effect is plausibly non-zero, even if small.
Yes I do have lazy enabled in all nodes (for no particular reason).
Let’s compare it for fun to ZFS+meta:
STORJ11
2024-08-10T19:30:20Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "55.70425ms"}
2024-08-10T19:30:20Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "42.627678ms"}
2024-08-10T19:30:20Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "39.131069ms"}
2024-08-10T19:30:20Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "41.33405ms"}
2024-08-11T19:30:21Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "975.175564ms"}
2024-08-11T19:30:22Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "898.093277ms"}
2024-08-11T19:30:22Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "38.547704ms"}
2024-08-11T19:30:22Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "43.088095ms"}
STORJ16
2024-08-11T19:31:30Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "36.440669ms"}
2024-08-11T19:31:30Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "30.411254ms"}
2024-08-11T19:31:30Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "232.38371ms"}
2024-08-11T19:31:30Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "35.852854ms"}
STORJ18
2024-08-12T14:08:59Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "43.430042ms"}
2024-08-12T14:08:59Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "37.188077ms"}
2024-08-12T14:08:59Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "36.387542ms"}
2024-08-12T14:09:01Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "2.112419639s"}
STORJ9
2024-08-11T19:38:34Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "41.244821ms"}
2024-08-11T19:38:34Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "34.747234ms"}
2024-08-11T19:38:35Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "1.135746884s"}
2024-08-11T19:38:36Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "1.156944714s"}
STORJ13
2024-08-12T15:45:36Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "45.333939ms"}
2024-08-12T15:45:36Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "47.658454ms"}
2024-08-12T15:45:36Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "79.829075ms"}
2024-08-12T15:46:40Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "1m4.55578921s"}
STORJ19
2024-08-12T19:04:37Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "2m53.268156766s"}
2024-08-12T19:04:37Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "167.713231ms"}
2024-08-12T19:04:56Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "18.993876373s"}
2024-08-12T19:16:05Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "11m9.56839617s"}
STORJ20
2024-08-12T16:58:15Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "2m19.787329739s"}
2024-08-12T16:58:15Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "279.184573ms"}
2024-08-12T16:58:15Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "92.092471ms"}
2024-08-12T17:13:15Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "14m59.421486746s"}
STORJ21
2024-08-12T16:00:55Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "158.374601ms"}
2024-08-12T16:00:55Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "75.406959ms"}
2024-08-12T16:04:10Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "3m14.913159103s"}
2024-08-12T16:04:10Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "110.280921ms"}
STORJ23
2024-08-12T15:24:02Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "7.399461132s"}
2024-08-12T15:24:03Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "59.410303ms"}
2024-08-12T15:24:05Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "2.132586046s"}
2024-08-12T15:24:24Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "19.622394935s"}
STORJ24
2024-08-12T16:58:43Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "3m16.584730004s"}
2024-08-12T16:58:54Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "10.929012865s"}
2024-08-12T16:58:54Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "150.575376ms"}
STORJ3
2024-08-11T15:27:15Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "112.721518ms"}
2024-08-11T15:27:15Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "42.657427ms"}
2024-08-11T15:27:15Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "64.109684ms"}
STORJ7
2024-08-12T15:06:20Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "19.715132444s"}
2024-08-12T15:06:57Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "36.966626481s"}
2024-08-12T15:06:57Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "115.147517ms"}
2024-08-12T15:06:59Z    INFO    pieces:trash    emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "1.089419864s"}
For a real comparison, I think we need to compare time per deletion actually.
Although, this is about a magnitude 50 lower than the figures above.
@JWvdV can you please post used-filewalker times with TB sizes of your nodes? Thank you
See: Badger cache filewalker test results - #48 by JWvdV
That is GC Filewalker. I’m interested in used Filewalker (Startup scan). The runtimes per TB are different i think.
This one:
cat /mnt/x/storagenode2/storagenode.log | grep "\sused-space" | grep "\(started\|completed\)"
I see, since I have quite aggressive log rotation (–log-opt max-size=20m --log-opt max-file=3) I just restarted a bunch of them:
STORJ10 # 3TB
2024-08-13T04:52:01Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:52:01Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:52:01Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T04:59:03Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 890500477440, "Total Pieces Content Size": 888702433792}
2024-08-13T04:59:03Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:59:03Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:59:03Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T04:59:11Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 47001358592, "Total Pieces Content Size": 46908655872}
2024-08-13T04:59:11Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:59:11Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:59:11Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T05:05:29Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 1259765037060, "Total Pieces Content Size": 1254600745476}
2024-08-13T05:05:29Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T05:05:29Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T05:05:29Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-08-13T05:06:31Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 387131132160, "Total Pieces Content Size": 386590395648}
STORJ11 # 0.5TB
2024-08-13T04:52:23Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:52:23Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:52:23Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T04:52:55Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 227808244258, "Total Pieces Content Size": 227148784674}
2024-08-13T04:52:55Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:52:55Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:52:55Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-08-13T04:53:02Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 66515747840, "Total Pieces Content Size": 66392520704}
2024-08-13T04:53:02Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:53:02Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:53:02Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T04:53:10Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 128053861376, "Total Pieces Content Size": 127885892096}
2024-08-13T04:53:10Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:53:10Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:53:10Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T04:53:11Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 2834916608, "Total Pieces Content Size": 2828171520}
STORJ16 # 0.5TB
2024-08-13T04:53:18Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:53:18Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:53:18Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T04:53:27Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 65639043584, "Total Pieces Content Size": 65469804032}
2024-08-13T04:53:27Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:53:27Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:53:27Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T04:53:29Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 10634523648, "Total Pieces Content Size": 10606732800}
2024-08-13T04:53:29Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:53:29Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:53:29Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T04:54:21Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 346617034520, "Total Pieces Content Size": 345533433624}
STORJ17 # EXT4 on SSD, for reference; 0.5TB
2024-08-13T04:53:38Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:53:38Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:53:38Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-08-13T04:53:43Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 32196163840, "Total Pieces Content Size": 32119192320}
2024-08-13T04:53:43Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:53:43Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:53:43Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T04:54:09Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 344013348612, "Total Pieces Content Size": 343274887428}
2024-08-13T04:54:09Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:54:09Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:54:09Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T04:54:13Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 68690767616, "Total Pieces Content Size": 68608271616}
2024-08-13T04:54:13Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:54:13Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:54:13Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T04:54:13Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 4209922048, "Total Pieces Content Size": 4200346112}
STORJ18 # 3TB
2024-08-13T04:54:57Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:54:57Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:54:57Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T05:05:22Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 938577181838, "Total Pieces Content Size": 936411291790}
2024-08-13T05:05:22Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T05:05:22Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T05:05:22Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-08-13T05:05:56Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 72643104512, "Total Pieces Content Size": 72516547840}
2024-08-13T05:05:56Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T05:05:56Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T05:05:56Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T05:06:02Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 27312897792, "Total Pieces Content Size": 27270129920}
2024-08-13T05:06:02Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T05:06:02Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T05:06:02Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T05:08:35Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 762508779008, "Total Pieces Content Size": 761121308160}
STORJ22 # 1TB
2024-08-13T04:54:57Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:54:57Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:54:57Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-08-13T04:55:09Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 41344751616, "Total Pieces Content Size": 41265071616}
2024-08-13T04:55:09Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:55:09Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:55:09Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T04:56:07Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 304844020258, "Total Pieces Content Size": 304035829282}
2024-08-13T04:56:07Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:56:07Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:56:07Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T04:56:31Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 263461012224, "Total Pieces Content Size": 263069980416}
2024-08-13T04:56:31Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:56:31Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:56:31Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T04:56:32Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 5588632064, "Total Pieces Content Size": 5579868672}
STORJ4 # 3TB
2024-08-13T04:58:13Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:58:13Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:58:13Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T05:09:53Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 1115101325312, "Total Pieces Content Size": 1113024720896}
2024-08-13T05:09:53Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T05:09:53Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T05:09:53Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T05:09:57Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 37095817728, "Total Pieces Content Size": 37039313920}
2024-08-13T05:09:57Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T05:09:57Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T05:09:57Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T05:13:15Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 1063926745142, "Total Pieces Content Size": 1060968851510}
2024-08-13T05:13:15Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T05:13:15Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T05:13:15Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-08-13T05:13:56Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 265432404224, "Total Pieces Content Size": 264996960000}
STORJ6 # 0.5TB
2024-08-13T04:55:49Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:55:49Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:55:49Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T04:55:51Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 12220630272, "Total Pieces Content Size": 12207375616}
2024-08-13T04:55:51Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:55:51Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:55:51Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T04:56:51Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 302004992256, "Total Pieces Content Size": 301490018048}
2024-08-13T04:56:51Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:56:51Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:56:51Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T04:58:03Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 384830724170, "Total Pieces Content Size": 383861209674}
STORJ9 # 1.5TB
2024-08-13T04:56:47Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:56:47Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-13T04:56:47Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
2024-08-13T04:59:01Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 559340285474, "Total Pieces Content Size": 557970750498}
2024-08-13T04:59:01Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:59:01Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-13T04:59:01Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-08-13T04:59:11Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 129081666304, "Total Pieces Content Size": 128883099392}
2024-08-13T04:59:11Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:59:11Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-13T04:59:11Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-08-13T04:59:13Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 17714196224, "Total Pieces Content Size": 17678229760}
2024-08-13T04:59:13Z    INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:59:13Z    INFO    lazyfilewalker.used-space-filewalker    subprocess started                             {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-13T04:59:13Z    INFO    lazyfilewalker.used-space-filewalker.subprocess                                        Database started {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-08-13T05:00:25Z    INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 560608152320, "Total Pieces Content Size": 559490173184}
Boils essentially down to 2-4m/TB
I get similar numbers with lvm+ext4. Matches what you suggested/shown – that deletions would see a bigger difference than filewalker since it involves writing HDD with a read cache.
6.5TB used cold start - 11 minutes
2024-08-12T19:56:07Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-12T19:56:17Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 134400850688, "Total Pieces Content Size": 134240108288}
2024-08-12T19:56:17Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-12T19:56:18Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 11949449216, "Total Pieces Content Size": 11933039104}
2024-08-12T19:56:18Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-12T20:05:41Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 5604319104000, "Total Pieces Content Size": 5595958433280}
2024-08-12T20:05:41Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-12T20:06:58Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 603438930436, "Total Pieces Content Size": 601651044356}
So, between LVM+EXT4-metadata… and ZFS-special-metadata… Linux users have a couple options to get sub-5-minute-per-TB filewalkers.
Windows doesn’t have a similar Storage Spaces config (that uses SSDs for metadata)? BadgerDB to the rescue?
That’s why I moved to Hyper-V VM with HDD passthrough as I still need to be on Windows. No regrets so far, doesn’t need much RAM/CPU, works great.
Challenge with Storage Spaces is that I don’t think you can partition a single SSD to cache multiple spaces/nodes. Would require to go all in with RAID and mirror/parity. Primo cache maybe. Badger is probably the best hope for individual NTFS nodes.
They have… But limited options
