Stob
August 9, 2022, 8:36am
2
Hi @RulAG
Please check your log file and post the results.
Stob
August 9, 2022, 11:31am
4
RulAG:
FATAL Unrecoverable error {“error”: “trust: malformed cache: invalid character ‘\x00’
Great, so the issue is a malformed/corrupt cache file. You can delete the trust-cache.json
file and it will be recreated next time you start the storagenode.
That’s what Alexey proposes:
To fix an issue - please:
Stop the storagenode service either from the Services applet or from the elevated PowerShell:
Stop-Service storagenode
Check disk for errors with correction.
Remove the trust-cache.json from the data location
Restart the storagenode service either from the Services applet or from the elevated PowerShell:
Restart-Service storagenode
Check your logs.
RulAG
August 9, 2022, 11:39am
5
Amigo muchas gracias!!!
Se ha solucionado, de verdad gracias!!
