Hello,
Is it possible to migrate my hdd to another pc in another location with another ddns address? I want to merge my 2 nodes together in one system. All I need is the identity right?
TiA
Hello,
TiA
The node doesn’t care about ddns. All it care is the identity. But if you have two nodes you need to run two instance of storj. Remember the limit /24 subnet.
I’ll add that you need the identity AND data. They are tied together and one without the other is useless.
